1 - 7 of 7 Posts
2007 Trailblazer SS
I have a aftermarket fan controller on my tbss but i need to know what wire i could tap into without going straight to the compressor for the a/c trigger.
Is there any other place i could tap into?
'08 TrailblazerSS
Does your compressor clutch connector have 2 wires or 3 wires. If it has 3 wires, you can tap at the hvac control module. If it only has 2 wires, you will have to tap in the engine compartment.
2007 Trailblazer SS
I have 3 wires at compressor. And I have the digital a/c hvac module in dash. What wire do I tap into?
'08 TrailblazerSS
At the hvac control module connector 1, pin B12. Light Green wire.
Reactions: Mitch808
2007 Trailblazer SS
Ground output at that wire correct?
Also when the compressor cycles will will the output change or it will be constant?
And thank you for the tech support.
'08 TrailblazerSS
Its positive and yes the output will cycle with the compressor.
1 - 7 of 7 Posts
