1 - 3 of 3 Posts
2007 tbss 2wd
what do you guys think i have 16.8 rims and finding drag radials for them so far is a biatch. i want to run m and h but the tire is for a 9 inch rim. i know it will work but will it look absolutly retarted or what? thanks for any help
Administrator
16x8 inch wheel 255 60 15 works 26x10.5x16 works 27x10.5x16 works. im using 275 40 17 drag rads and they pull a lot harder than stock off hte line and 1/4 mile is perfect because you will be in the high 5000 rpm range going thru the lights where as stock tire which is a lot taller will be midway into 3rd. also 275 40 17 mounted with tires are like 40 pounds lighter than stock.
2007 tbss 2wd
so you would say no to getting the m and h 275/55 r16? its 28 in diameter and stock i think were at either 30 or 31 stock. but thanks for the help i just feel that the 10.5 x 16 might look really stupid but if the hookup i guess who cares haha
1 - 3 of 3 Posts
