1 - 2 of 2 Posts
06 TrailblazerSS
I'm looking to add a fuel pressure sensor to log my pressure at the rail though the Pro Link+ cable on my HP Tuners setup. Is it ok to tap 5v power from another sensor under the hood, or am I better off using some sort of stand alone regulated supply? This just going to be temporary to do some troubleshooting if that makes a difference. Thanks.
'07 3SS 2WD
Tapping under the hood should be fine (as long as you don't F it up..). It's just a reference voltage that is regulated from the ECU, and then spliced to the sensors that would need it.
1 - 2 of 2 Posts
