Just got my 4L80 installed and the magnaflow y pipe doesnt fit. I kinda have an idea of what i am going to do but was just curious what other peoples exhaust with the 80e turned out.
So do you now have selectable 2wd <>4wd now with a 4l80? Time to go junk yard shopping if so.I started with full tube headers with non cat y pipe, but in washington state I still needed cats. I chopped the y pipe and inserted two cats just behind the crossmember then installed a y and a new flex pipe altered the pin for the rubber mount and connected back to the stock two bolt flange. After splintering a hardened output shaft in the beefed up 4l70 I swapped in a 4l80, thankfully I did not need any mods to my modified y pipe when I installed the 07 4l80 (all the latest updates) and a transfercase from a 99 full size truck/suburban with push button shift and awd option. I have a pic but can not get it to load
