I've decided on doing a 402 build and I'm going over on what all i need to be ordering so i can get started so you guys let me know what all I'm missing cuz i know ill miss a fiew things. this is the first ls engine build I've done I've done quite a view other types of engine mainly 4 cylinders n smaller but I'm confident in doing it all. and I'm just talking about engine stuff here I'm replacing trans n stuff too but thats another thing. so far heres what I've planned out
408 rotating assembly from cnc motorsports ( in my ls2 will be 402 ) going with a dragonslayer crank, JE stock bore and compression pistons, compstar I beam rods
machining my block for clearances ( which ill do myself )
wcch l92 heads kit and a custom spec cam from alvin
injectors
gonna do a FAST intake
main caps and bolts ( where should i get these? )
gonna do a moroso or c6 oil pan so everything to do that
all gaskets and new head studs
i allready have
kooks 1 7/8th headers
ls1 efans
pcmforless 4 in cai
hsw sudden impact nitrous
this was just a quick list off the top of my head
should the factory fuel system be able to keep up with this motor alone? theres going to be a stand alone fuel system for the nitrous as I'm going to do a plate system for a first stage and direct port for a 2nd stage
any suggestions or parts I've missed as i said I'm sure I've forgot some things i just woke up n was thinking about everything i need to order n figured id post up.
and again yes yes yes i know trans it is in the plains lol
injectors
i allready have
ls1 efans
pcmforless 4 in cai
