1 - 4 of 4 Posts
Sorting oil system (baffles,pump blah blah blah)
402 with ARP main stud...had to drill out pcm mount hole no big deal, spaced out tray and used a flanged bolt on the tray. Spacing still not enough after torquing to 18ft and I do not believe I will have anywhere near the thread available to
Also mount the tube is there something I'm missing.... 2x washers won't clear stroke
3x washers leave no thread for tube.
if not I believe I found the solution in a mast stroker tray made to accommodate up to 4.2 range stroke and multiple pick up styles. But wanted to see if any other users that had this before I drop roughly $100 on a tray.
08 trailblazer SS
Factory tray should need some trimming to fit, its on the directions that pcm sends with the kit.
Got the tray cut and tube fit they only thing I'm worried about is the threading left to mount the tube (LAST PICTURE)
^thats with an oring in there & no boot still a pretty good seal and I have a girdle coming and more rings for actual install.
And here is the thread issue concerning me.
1 - 4 of 4 Posts
