1 - 5 of 5 Posts
Hi,
I am currently converting a 2WD trailblazer to AWD.
I am almost finished. The last step is to remove the 2WD transmission tailshaft and bolt up the AWD transfer case. My question has to due with the transmission output shaft. The 2WD and AWD are different. Can the input shaft be removed and replace without removing or taking apart the tranny.
Does the shaft just "pull out"
Thanks
The entire transmission has to de disassembled in order to pull output shaft
1 - 5 of 5 Posts
