1 - 9 of 9 Posts
Which has the better times? Is it a big difference?
2006 TBSS (LT Based)
From what I have been told, the AWD launches harder, but you also have extra weight from the front differential and transfer case. I would think the two wheel would for that reason. :2cents:
'06 TBSS
Stock for stock RWD is faster in the quarter by about .2-.3
Some PCM of NC bolton's
:iamwithstupid: Think of it this way AWD is 300-500 lbs heaver I think, so if all you want is speed go w/ a 2wd
'06 TBSS
Not to mention the extra parasitic loss....
H
Guest
A 2WD is technically faster, however depending on the driver and conditions, an AWD could pull a 2WD from a dig
1 - 9 of 9 Posts
