1 - 20 of 20 Posts
2006 Red Jewel AWD
So yesterday I went to get a tire rotation and rebalance and I was just over 1/32" off the wear bars, so I went ahead and had them install new shoes...The 265/50's are 3/10" wider and 4/10" taller than stock.They sit just over 1/8" off the upper shock mount/control arm, is that going to be too close? it hasn't rubbed at all and I like the way they fill the weel well a bit better...
Tony, any insight on this subject since you are the leading authority?
· Registered
07 1SS
Many people have gone w/ those, you are fine. Just loose a little perf w/ the taller tire.
dam it evil i have a fat hookup with toyo tires thru my buddy. my 255 45 20 and 275 45 20 were less than 600. for a 265 50 20 i could prob get them for like 525-550
2006 Red Jewel AWD
Discussion Starter · #9 ·
You know Tony, I totally spaced on that...DAMMIT im retarded...
Get me a price on 265/50vr20's and I may just have to return mine...they will take them back for any reason, I am really not happy with the siping at all right now...
The are about a 1/4" to a 1/2" close, but I've had it up to 135 and no problems...even took them off to inspect for rubbing on the fronts after a while and I got none. They fit because they are mounted on the factory 8" wide rim, if they were mounted on an 8.5" wide wheels the backspacing would have to be adjusted most likely
· Registered
'08 Silver TBSS
Holy old thread!
Performance hurts because the taller tire effectively raises (numerically lowers) the final drive ratio. Since they're only 4/10" taller its not a lot. Also the speedo will run slower by a mph or 2.
'08 Silver TBSS
Reactions: rrmccabe
· Registered
Holy old thread!
Thank you
1 - 20 of 20 Posts
