1 - 18 of 18 Posts
Mattmikemark
2006 Trailblazer SS
That white truck is gay as fuck.
30.5......Really? I thought it would have been 31.25. How is the ride quality? Not bouncy i hope.....
Mattmikemark
2006 Trailblazer SS
At least the white truck has the 31.5" rear springs. With those tires I bet it sits around 32", ground to fender lip.
Mattmikemark
2006 Trailblazer SS
White truck is justanotherssuv. I'll text him and let him know you're looking for him lol
making friends daily
07 TrailblazerSS AWD
From the ground to fender lip my truck sat at 30 3/4" in the front and 31 3/4" in the rear. That was with the belltech struts/djm uppers in the front and belltech 31 1/2" spring/shock combo out back.
OP,
You should see his TBSS now. He has 0 fender gap and now has to measure ride height from the frame to the ground. Lol
2006 white 2wd
Just an FYI... Two tires of the same size, but different brand, will have different measurements. If you need specific tire heights and widths, you will need to look up the specs of the specific tires you are looking at. I hope I didn't confuse you.
2006 white 2wd
Also, if you put a wide tire on a rim that is smaller than suggested, the tire will be taller than what the specs are from the tire manufacturer. There are several factors in tire measurements, you can't just go off pictures of other rides especially if you need exact measurements.
Administrator
265 50 20 in 20x8
295 45 20 on 20x10
31 front with drop struts
31 9/16 with my rear 31.5 kit
Done
265 50 20 in 20x8
295 45 20 on 20x10
Done
Pretty much exactly what I already told him minus the 'done' lol
Mattmikemark
2006 Trailblazer SS
Brandon what spacers did you have on your belltechs? Seems like you liked the 1" raked look.
I think just one of the small spacers. For some reason these things look goofy to me completely level. That and my back end liked to squat pretty decently on launches from 4200 rpm lol
1 - 18 of 18 Posts
