1 - 1 of 1 Posts
I have a 2006 SS. I just replaced all the brake rotors and pads. While it was apart I noticed the rear axle seals were starting to weep. My question is what are the correct part numbers for the axles and seals? I tried looking them up and no listing had the option for a 9.5 inch rear gear. I know I have a 4.10 ratio and it is a posi-traction. I have the rear axle cover gasket (GM Part # 26063649) and it is correct. The part numbers I got for the axles are (Left 88965786) (Right 88965787) but the listings say they are for a 8.5 inch rear gear. The seal part number I got was (22761722). Are the part number I have correct? What is the correct ring gear size, 8.5 or 9.5 inch? As a side note, does the pan hard rod need to be removed to get the axle cover off? Any help would be great. Thanks.
1 - 1 of 1 Posts
