1 - 11 of 11 Posts
· Registered
Speedometer and transmission won't shift into drive. This happened after it was stuck in 4wd and I manually shifted it back into 2wd. When I test drove it is when the speedometer wasn't working and tranny not shifting into drive. Park reverse 1st and 2nd is all I got. Any ideas. Been thinking a sensor but wow vss or abs speed sensor. Idk, vss is the one that seems to match the problems I'm having. Any advice or suggestions. I've pulled every fuse using a test light which did no good. I have electrical issues. I have no idea where to begin to fix it either.
· Registered
2008 TBSS Red Jewel RWD
Sounds like the shifter cable fluid is low. Fill it up and your problem will be solved.
2008 Black TBSS
You do realize this is a website for the Trailblazer SS which was made only from 2006-2009. We have both a different engine and a different transmission. There might be a better forum out there for you. That said, I'd check your forward sprag. Speedometer may or may not be a separate issue
· Super Moderator
Comon we all know the cam stopped camming..
· Registered
May be an electrical problem. Buy a box of amps and a bucket of ohms and start adding until working properly…
· Registered
Well actually I did not realize this for TBSS owners only, my bad
· Registered
Shifter cable fluid? WTF are you talking about Moto?
It doesn't seem to me that the TBSS folks are kicking the doors down to post here. Maybe you should reconsider your self-righteous, surly policy and help ALL Trailblazer owners, eh?
1 - 11 of 11 Posts
