1 - 20 of 36 Posts
This is still using the 4l70e. Don't mind a converter of I have to.
Is this attainable NA or am I looking at forced induction?
Thanks!
making friends daily
07 TrailblazerSS AWD
It seems that 12.5 is almost pretty standard for full bolt ons, cam, stall and a little bit of weight reduction. Or, a supercharger or a semi healthy shot of the nitrous with a stall.
Next question, and forgive my newbie ness here...
Are the TBSS exhaust manifolds the same as the truck manifolds?
Mattmikemark
2006 Trailblazer SS
The exhaust manifolds are different than full size trucks. Lots of guys doing LS swaps use the Trailblazer SS exhaust manifolds because they actually flow pretty well and coming off a trailblazer means they can fit on a narrow framed car/old truck.
TrailblazerSS AWD
you NEED a stall. you wont go anywhere without one.
Most popular stall for awd to get these fat pigs moving is a 3600.
3600 stall, E-fans, 4inch FWI, headers & y pipe, plus some weight reduction you might be able to hit 12.5 depending on DA and other things.
Add a cam to that mix and your at 12.5 with ease.
2008 Black TBSS
I think I could get to 12.5 with a stunt driver once I go with a LS7 MAF. Most of the mods are in signature plus seats out for weight reduction to offset oversized driver and smaller diameter tires.
needs moar powa
Cam and full bolt ons awd with just the spare removed I went 12.6 .
A lot of guys do way better with some lighter wheels and some weight removed, it's easily achievable.
A built trans is recommended and probably the most expensive piece of the puzzle.
Do you still want the truck to be the same as it is today? Or do you want to make compromises? Like it has been said you can do H/C/I + stall + exhaust and it'll probably be a fair bit rowdier; or you can boost it (which will cost more) and the truck will be more civil.
I went with boost to keep the truck feeling "normal". Granted I bought a small stall, built trans, headers, intake, LS9 cam and LS7 lifters, springs, pushrods, fuel mods, etc to support the blower.
There are many different ways to skin these heavy pigs.
6.2 silverao
My lt1z cammed went 12.8 in crappy DA, full weight, and a small 3k stall. Good DA is very obtainable with a well put together setup cam only
A 1900 maggie will do with stock stall/trans and I think stock manifolds.
And drive stock.
Cam, 3600 stall, full bolt ons, 17" wheels, and weight reduction gets me consistent 12.1's in good air. My trany is bone stock.
Discussion Starter #18
Awesomee comments. Thanks!
Is there a used buyers guide form these things? I am a heat duty mechanic, but it'd be good to know what to look for. There a few around, some with higher mileage. Should I be scared of them? I'm ready set on no modifications, want a rear dvd for the kid, and am selling my 1992 Typhoon for it.
1 - 20 of 36 Posts
