1 - 8 of 8 Posts
Hey everyone, my 06 AWD, just turned 100k and I'm curious what needs to be done. I purchased the truck CPO with 42k miles, it had new rotors/pads, tires, etc. I plan on keeping it to 150k and beyond!
Since then, I've added a trans cooler, tune, plugs, etc.
Here's what I'm thinking needs to be changed:
Trans fluid change/flush
Diff fluids
Xfer case fluid
Radiator flush
Please let me know if I'm missing anything(besides a built trans :biggrin2:)
Thanks.
Already did the muffler bearings.....:yay2:
Central NJ, Freehold and you?
Matt, I did the plugs with the tune, cai, fans, etc, all around 85k miles.
What wires would you suggest?
2007 Trailblazer SS
Check your outer tie rod ends and ball joints.
07TrailblazerSS
Piston return springs:D Check all suspension bushings as stated above, hoses, belt, tires, fuel sensor/filter, wheel bearings
1 - 8 of 8 Posts
