1 - 20 of 123 Posts
07TrailblazerSS
Just installed my 1 inch wheel adapters on the rear of my 07 and it looks MEAN!!!! Pics will be up tonight. 79.00 for billet aluminum with grade 8 studs and lugs
Nate
Post pics .... Also pm me website
07TrailblazerSS
Ill get you guys info when im off work...
Reactions: blue demon
07TrailblazerSS
07TrailblazerSS
pics will be up tomarrow...sorry guys
07TrailblazerSS
Discussion Starter · #10 ·
Could I run these with the FR 20x10 combo I am running out back?
i was able to run them with my stock wheels. the 1 inch spacer allows the stock lugs to run though the spacer about a 1/8th of an inch which at first look seems as though the wheels wont mount up. the stock wheels have resessed points on the mating side of the wheel that allow the wheels to mate to the spacer without any issues....if that makes sence. if you have the same casting mating surface as the factory wheels then yes. if you look at the backside of a stock wheel you will see what im talking about...kind of hard to explain
Nate
Bud those are not hub centric. Your rear wheels will run like if they are not balanced. Plus those ate kinda of unsafe you are carrying the whole load of the car on six lugs in difference when you carry them on 6 lugs and the wheel
Hater
Duh
About 10 years ago a buddy of mine was using those on his s10 so he could run a front drive style wheel. Whether or not it was the part I don't know cause he would hammer the dog shit out of em with an impact. But he was driving down the street and one of the rear wheels broke off and just about tore the side of the bed off.
I know I am missing something but what is the reason for the Spacer anyway?
07TrailblazerSS
Discussion Starter · #16 ·
To bring the wheel out to the fender lip. it looks sooo much better than the stock sunk in look....at least i think so. The look from the rear is even better. I need to post pics but ive been busy as hell.
07TrailblazerSS
Discussion Starter · #17 ·
They are hub centric. Ive been 100mph and absolutley no signs of balance issues.
just saying they are unsafe... if they are they dont like it at all in the pic....
07TrailblazerSS
Discussion Starter · #19 ·
I definatley will check the torque on the lugs frequently
1 - 20 of 123 Posts
