1 - 8 of 8 Posts
The SLP TVS 1900 has a pressed on pulley, I have search all over online and found nothing.
I was wondering if someone on the forum or one of you knows where i can buy a smaller TVS 1900 pulley. Again its a pressed on pulley not a 4 bolt one...probably one of the FIRST SLP superchargers.
My other option for upping boost is the Innovators 10% overdrive (which I may do anyway). Question about this, do I need to do anything else with the crank or engine to install this crank pulley or will it just go right on?
Thank you
removed the pressed on pulley and install the 4 bolt hub, and then have fun with with the many choices on pulleys. i did this with my old tvs 1900 i had. i cant seem to find it listed anywhere, but i got mine from superchargersonline. i dug up my invoice and this is what the part number was
M-69-00-87-010
MAGNUSON SUPERCHARGERS 2 PIECE PULLEY HUB - and at the time i purchased it, its was a wopping $35 lol
give em a call, or maybe even magnuson can help you, or your other favorite supercharger parts supplier
They had the exact part number. I ordered it, its 75$. BUt to be clear this is the my supercharger snout, the partnumber i ordered that matches yours, isnt the snout but where the actually pulley sits and then I can add all the other maguson pulleys? Because this will be so much better! lol
M-69-00-87-010
Also, do you remember what pulley offset you had to run? There are so many options. lol
no i do not remember the offset. correct the part # i gave you, you use a 2 or 3 jaw puller and remove your pulley from the snout, then use a power steering pulley installer and you install the new 4 bolt flange. then just bolt what ever 4 bolt pulley you want. and isnt the tbss truck oulley offset?
Should be a quick job and I have no idea, i am trying to find it online. My buddy has a could 8 rib ones i can stick on, they all have different offsets and i can use that to figure it out.
One more thing, did you ever install a boost gauge? If so where did you tap for the vacuum because there isnt a single spot on this thing to put a vacuum line on that i can see.
1 - 8 of 8 Posts
