1 - 18 of 18 Posts
2007 TBSS
07 TBSS
Its a 2007 3SS AWD with every option except rear DVD.
Painted GM Sunset Orange Metallic with a carbon fiber Scott's cowl hood and dual rear valance.
Mods include a forged 402 LS2 stroker, Trickflow heads, ARH longtube headers, TVS 2300 supercharger on 8psi, RPM level X 4L70E, Cicle D triple disc 3200 stall, AIS meth kit, Accusump, Baer 6 piston brakes in all corners. Truck has gone 11.2 @ 124
402 cubic inch LS2 block
11.3:1 compression
4" callies compstar crank
callies compstar rods
wiseco pistons
arp hardware
Trickflow 225cc CNC'd heads (stamped on passenger head)
RPM spec'd comp cam
comp roller rockers
Trickflow pushrods
Melling oil pump
ARH 1 7/8 headers
ARH y pipe with gutted cats
Magnaflow catback
DMH electric cutout
Maggie tvs2300 front drive
rds blower spacer
AIS dual nozzle meth kit (100% meth)
Full 8 rib conversion
Meizere electric water pump
PCMofNC fender air intake
LS7 MAF
LS1 fbody electric fans
Original color was Imperial Blue. Paint job was done right. Door jams and engine bay are painted.
Engine has right around 7K miles, trans/supercharger has a little over 2,000 miles.
Only issues at the moment: rear exhaust needs to be completed to dual outlet, intermittent clicking sound from under the dash (thinking blend door). Will be addressing these issues when I get a chance. If someone is interested in buying it now the price would be dropped some.
$23,000
Sold
07 TBSS
11.3:1 compression
wiseco pistons
arp hardware
RPM spec'd comp cam
comp roller rockers
Trickflow pushrods
Melling oil pump
ARH 1 7/8 headers
Magnaflow catback
DMH electric cutout
rds blower spacer
LS7 MAF
$23,000
Sweet truck! GLWS!
Nice truck. Great options
2008 TBSS Super Charged
A well built ride for someone looking for something ready to go!
Did you have to check your rear axle runnout dimensions before installing the 6 piston calipers in the rear?
I have the Baer 6P kit all around. The rears you have to shim properly. If you don’t, the axle run out will rub on the caliper a little bit. If shimmed properly, you wont have any issues. You just have to get the caliper centered on the run out amount.
'07 3SS 2WD
Saw one that looked to be very similar to this color running around the greater Phoenix area last week.
1 - 18 of 18 Posts
