Give it a few, Lingenfelter is developing one now.......160 that is!For an N/A application.....Should I bother? I remember reading that the stat changed between 06 and 07 models. Does anyone make a 180 stat?
My 07' stays at 210 litterally from the minute I start it up, so I doubt it has a 180.
what I want to know is can I just change to a 160 stat even thow am not throwing on e-fans I just got a CAI no resonator flowmaster I just want to run cooler.. Also what brand is everybody using can I just get one from NAPA or whatThe 2007 has a 196º factory t'stat. They use fan modulation to keep temps above t'stat set temp so the water pump does not get loaded down.
Remember, you always want the t'stat opening to happen at a lower temp than the actual engine temp, to unload the restrictive effect on the pump and the resulting horsepower loss of driving a high static pump head.
Sure you can, it will run cooler at speed and just as warm at idle or at traffic lights, unless it's cold out.what I want to know is can I just change to a 160 stat even thow am not throwing on e-fans I just got a CAI no resonator flowmaster I just want to run cooler.. Also what brand is everybody using can I just get one from NAPA or what
So where is everybody getting these lower temp stats at and how muchSure you can, it will run cooler at speed and just as warm at idle or at traffic lights, unless it's cold out.
No I wanna buy a 160 lower temp thermostatDo you mean how are we taking them?
Mostly coming from my DashHawk. But HPtuners as well.
Roger...Cool radio talk...I think Alvin said you can put it in the 07 if you use the original gasket over.
Thanks, Alvin.Yep,
All you have to do is re-use your factory o-ring gasket. Mine has been this way for around 9k now.
there not even out for the 07's yet and read my post above!what I want to know is can I just change to a 160 stat even thow am not throwing on e-fans I just got a CAI no resonator flowmaster I just want to run cooler.. Also what brand is everybody using can I just get one from NAPA or what
