**Official 1/4 Mile Fast List** - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > Racing > Track Racing
Track Racing Safer Form of Racing
Old Sep-25-13, 03:35 PM   #1
WongBob
High and Tight!!!
WongBob's Avatar
Real Name: Wade
Member # 5354
Casino cash: $452050
Like: 38
Liked 116 Times in 44 Posts
Rep Power: WongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud of
Default **Official 1/4 Mile Fast List**
Hello Fellow Racers, This is our **OFFICIAL** Fastest Drag Times Record Thread
I am taking over control of the ET record keeping thread that Jared and Notfast before him were maintaining. It takes a lot of time to do this and due to their lack of time or desire to keep up with the thread, I'll be the one updating this thread from now on with the help of TNSS. I choose to take the torch from Forcefed and I hope to keep the thread as up to date as possible. I want to extend my Thanks to Jared, Notfast and Forcefed for their work on this thread in the past. I think this thread helps us all to set goals for ourselves and to encourage more of us to get out and race, build and just enjoy the sport. Ill Make this a continual thread that will just continue from year to year.
This is the most important Part of this thread, it’s for times only, Not Discussions.
Please keep discussion in this thread to the posting of time slips and updated ETs.
If you want to have a discussion about someone’s times, send a PM or start another thread please.
Previous "Fast List" threads:
**OFFICIAL** Fastest trucks ET thread
**OFFICIAL** 2012 Fastest Drag Times Thread
We will be limiting the record spots to the top 10 Trucks in each class.
We will keep the bragging rights section I think that was a great add by Forcefed and we will also be adding one more class to help brake down the difference between built bottom end trucks and the stock bottom end trucks we will call this the Heads/Cam/Intake class or H/C/I for short.
"The Bragging Rights" will be a sitewide, cumulative Drag Times History.....See where you stack up against EVERYONE. It’s an Anything Goes, Complete Forum Drag History simply for bragging rights with your fellow members. This is just so you know where you stack up against any given truck. To be included, simply follow the Format as given and put "Bragging Rights" as the class if your not going to fall into a record holding spot. All trucks, regardless of class will be on this list, in order of times. If times are tied, fastest trap will break tie. The only limitation to this record, the owner must still own the truck....No previous records can stand. This is for current and active member owners. If someone doesn’t fit this bill, please let me know via PM and Ill verify it and remove the name from the list.
Here are your classes....Lets Get it ON!
Intake and Tune ONLY
- Any style cold air intake, LS7 card style MAF allowed
- E-fans are also allowed as they are required with some cold air intakes
- Any tune allowed
- Built transmission allowed, must be on STOCK torque converter
- Weight reduction allowed
- Any wheel/tire combination is allowed
- Engine blueprinting NOT permitted
Bolt on/stock internal
- "Bolt on" engine parts only. Must retain stock heads, cam, all valvetrain components, stock rotating assembly.
- Aftermarket rod bolts allowed.
- If heads have ever been removed, the replacement head gaskets used must retain stock compression.
- Any weight reduction, transmission, suspension, chassis work, wheels/tires are permitted
Cam only
- Camshaft and valvetrain may be modified, in addition to "bolt on" parts
- Heads must be entirely stock
- Fly Cutting allowed
Heads/Cam/Intake
- No power adders
- Engine must maintain stock rotating assembly
- Must be stock cubes
- No forged internals
All Motor
- No power adders
- No limits on engine modification
Stock Bottom End
- No Cam Or Power Adder Restrictions
Fastest AWD/RWD
- The baddest of the bad.
- No holds barred.
- Anything goes.
The Bragging Rights
- Everyone and Anything
- See where you stack up....SITEWIDE.
I will update this thread when new times are submitted.
Ill do this while I’m off work and have a little extra time or when time permits.
Please post in this thread your time submissions in the following format
If you do not submit them in this Format, I will not add them to the list until it’s corrected. Also include a picture of your time slip as proof.
user name - 60 ft - 1/8 ET @ 1/8 MPH - 1/4 ET @ 1/4 MPH – and what class or classes
EXAMPLE: Notfast - 2.00 - 8.5@80 - 13.5@100 –
Cam Only and All Motor stock bottom end
Please put your mods/weight in your post...I will try to keep the lists simple, but this thread will provide info for anyone looking for it.
Thanks in advance Everyone for your participation....Have Fun this year on the track and Good Luck!
Cam Only Record Holder 1.467 60', 11.568 @ 116.86
Naturally Aspirated Record Holder 1.484 60', 11.144 @ 119.46
http://www.tbssowners.com/forums/image.php?type=sigpic&userid=5354&dateline=1320607  794
Retro (Sep-25-13), SSilveronyxx (Oct-03-13)
Sponsored Links
Advertisement
Old Sep-25-13, 03:36 PM   #2
WongBob
High and Tight!!!
WongBob's Avatar
Real Name: Wade
Member # 5354
Like: 38
Intake and Tune Only
RWD
1. graceliz - 1.90 - 8.24 @ xx.xx - 12.84 @ 107.37
2. Chief - 1.87 - 8.26 @ 83.76 - 12.93 @ 105.61
3. Juiced - 2.003 - 8.505@84.65 - 13.024@106.74
4. Dark SSide - 1.95 - x.xx @ xx - 13.22 @ 103.98
5. NORCAL SS - 1.96 - 8.55 @ 81.94 - 13.30 @ 103.97
6. bobbyalex -2.07 - 8.58@ 83.52 - 13.31@ 103.71
7. NiGhTrYdeR - x.xx - xx @ xx - 13.34 @ 105.44
8. BOOSTEDBOSS - 2.052 - 8.632 @ 83.05 - 13.38 @ 103
9. tbss2650 - x.xx - xx @ xx - 13.44 @103.58
10.
AWD
1. SLOWHITE - 1.95 - 8.41 @ 84.44 - 13.08 @ 104.87
2. TWO-TONS-OF-FUN - x.xx - xx @ xx - 13.19 @ 103
3. psycho1 - 1.95 - 8.52 @ 83.34 - 13.31 - 102.26
4. GSMOOTH - 1.982 @ 8.975 - 13.378 @101.88
5. blue_beast - 2.036 - 8.681 @ 82.12 - 13.495 @ 101.94
6. ti28 - 1.99 - 8.75 @ 81.50 - 13.59 @ 101.17
7. OneidaSS - 2.0 - 8.7 @ 81.6 - 13.6 @ 102.16
8. 08HEAVYVETTE- 2.016- 8.737 @ 81.99- 13.6 @101.32
9. Purple87SS - 2.03 - 8.74 @ 81.08 - 13.63 @ 100.32
10. ObseSSion07 - 2.092 - 8.84 @ 80.3 - 13.74 @ 99.84
Bolt On/Stock Internal
RWD
1. Balistikss - x.xx - xx @ xx - 12.019 @ 112.21
2. Chief - 1.62 - 7.70 @ 88.2 - 12.12 @ 111.66
3. JohnnyGTA-SS - 1.63 - 7.76 @ 87.23 - 12.27 @ 108
4. skinnies - x.xx - xx @ xx - 12.34 @ 108.2
5. ssman07 - 1.64 - 7.84 @ 85.50 - 12.41 @ 108.xx
6. 2FNQUIK-1.747 - 8.108 @ 84.07 - 12.756 @ 105.90
7. dje08tbss - 1.760 - 8.162 @ 83.62 - 12.868 @ 104.31mph
8. SSMOKIN U - 1.785 - 8.221 @ 82.30 - 12.923 @ 104.97
9.
10.
AWD
1.justanotherssuv - 1.581- 7.625 @ 87.77 - 12.114 @ 109.02
2. Jared - 1.669 - xx @ xx - 12.5389 @ 106.92
3. 02silver2v - 1.663 - 7.931 @ 85.29 - 12.554 @ 106.32
4. endlink - 1.70 - 8.007 @ 85.88 - 12.59 @ 107.12
5. JA93 - 1.720 - 8.017 @ 85.34 - 12.623 @ 106.9
6. db-guru - 1.727 - 8.018@84.71 - 12.671 @ 105.49
7. martyjw597 1.687-8.012@84.43 - 12.672@105.35
8. MHENEL - 1.788 - 8.056 @ 84.91 - 12.697 @ 106.16
9. TWO-TONS-OF-FUN 1.84 - xx.x@ xx.x - 12.73 @105
10. blue_beast - 1.77 - 8.105 @ 84.34 - 12.789 @ 104.87
11. SWETRID - 1.79 - 8.19 @ 84.21 - 12.799 @ 108.04
Cam Only
- in memory of Shawn "Saladbar" Salazar
RWD
1. WongBob - 1.46 - 7.29 @ 91.83 - 11.567 @ 116.86
2. martyjw597 - 1.55 - 7.52 @ 88.25 - 11.91 @ 112.19
3.Jared - 1.549 - 7.52 @ 88.92 - 11.972 @ 109.82
4. blkscls1z - 1.62 - 7.64 @ 88.80 - 12.067 @ 110.78
5. ronn25 - 1.64 - 7.72 @ 88.15 - 12.15 @ 11.52
6. Saladbar - x.xx - xx @ xx - 12.25 @ 110
7. TWO-TONS-OF-FUN - 1.67- xx.x@ xx.x - 12.27 @ 109.8
8. SouthernTBSS - 1.873 - 8.071 @ 86.3 - 12.665 @ 106.2
9
10.
AWD
1. martyjw597 - 1.581 - 7.616 @ 89.48 - 12.033 @ 111.92
2. 08HEAVYVETTE - 1.667 - 7.657 @ 89.74 - 12.051 @ 111.61
3. Jared - 1.65 - 7.77 @ 87.69 - 12.277 @ 109.15
4 Juice - 1.71 - 7.788 @ 87.41 - 12.300 @ 108.73
5. hcblackblazinss - 1.770 - 7.903 @ 88.11 - 12.405 @ 109.19
6. Silverelex 1.73 - 7.95 @ 86.36 12.48 @ 107.56
7. TrueLS2 - 1.76 - 7.92 @ 86.41 - 12.49 @ 107.44
8. ja93 - 1.696 - 7.929 @ 86.14 - 12.504 @ 106.35
9. TWO-TONS-OF-FUN 1.78 - xx.x@ xx.x 12.51 @107
10. soon2bss 1.73 - x.xx @ xx.xx - 12.51 @ 106.xx
11. PeteG06SS 1.74 - 8.06 @ 85.03 - 12.57 @ 107.54
H/C/I
RWD
1.WongBob - 1.484 - 7.030 @ 95.33 - 11.144 @ 119.46
2.TNSS - 1.54 - 7.16 @ 95 - 11.34 @ 117
3.Martyjw597-1.52-7.35 @ 91.66 - 11.635 @ 115.71
4.
5.
6.
7.
8.
9.
10.
AWD
1. swat ss - 1.68 - 7.628 @ 90.07mph - 11.96 @ 111.76mph
2. martyjw597 - 1.581 - 7.616 @ 89.48 - 12.033 @ 111.92
3. 1SickSS - 1.743- 7.888@87.98 - 12.369 @109.93
4. UrbanSS17 - 1.85 - 8.03@ 87 - 12.46@ 109
5.
6.
7.
8.
9.
10.
All Motor
RWD
1. WongBob - 1.484 - 7.030 @ 95.33 - 11.144 @ 119.46
2. TNSS - 1.54 - 7.16 @ 95 - 11.34 @ 117
3. Martyjw597-1.52 - 7.35 @ 91.66 - 11.635 @ 115.71
4. MM3EAVES - 1.757 - 7.501 @ 94.60 - 11.664 @ 118.3
5. 1GMfanatik - 1.60 - xx @ xx - 11.70 @ 115
6. devus1 - 1.64 - 7.62 @ 90 - 11.76 @ 114
7. Moore0501. 1.719, 7.549@90.36, 11.77@117.01
8. Blacksheep - x.xx - xx @ xx - 11.79 @ 116
9. freemaSSon - 1.618 - 7.483 @ 90.87 - 11.828 @ 112.710
10. NASTYSS - x.xx - xx @ xx - 11.84 @ 114.06
11. PipeDreams - 1.817 - 7.947 @ 88.11 - 12.442 @ 109.14
12. 02silver2v - 1.663 - 7.931 @ 85.29 - 12.554 @ 106.32
AWD
1. Dustin. - 1.65 - 7.448 @ 91.33 - 11.70 @ 116.90
2. Jake747 - 1.61 - 7.49 @ 91.7 - 11.83 @ 113.17
3. tracman466 - 1.65 - 7.56 @ 90.19 - 11.891 @ 113.68
4. HEMILLER3 1.766 - 7.630 @ 93.01 - 11.935 @ 114.73
5. swat ss - 1.68 - 7.628 @ 90.07mph - 11.96 @ 111.76mph
6. martyjw597 - 1.581 - 7.616 @ 89.48 - 12.033 @ 111.92
7. 08HEAVYVETTE - 1.667 - 7.657 @ 89.74 - 12.051 @ 111.61
8. justanotherssuv - 1.581- 7.625 @ 87.77 - 12.114 @ 109.02
9. pharmd - 1.778 - 7.751 @ 88.945 - 12.175 @ 109.730
10. Jared - 1.65 - 7.77 @ 87.69 - 12.277 @ 109.15
11. Mflow2 - 1.74 - 7.81 @ 88 MPH - 12.29 @ 109.9
12. Juice - 1.71 - 7.788 @ 87.41 - 12.300 @ 108.73
13. hcblackblazinss - 1.770 - 7.903 @ 88.11 - 12.405 @ 109.19
Stock Bottom End
RWD
1. Ronn25 - 1.46- 6.70 @ 102.55 - 10.514 @ 128.57mph
2. All Ull C - 1.54 - 6.80 @ 101 - 10.66 @ 127
3. WongBob - 1.484 - 7.030 @ 95.33 - 11.144 @ 119.46
4. TXBlownTBSS - 1.64 - 7.21 @ 95.XX - 11.28 @ 122.00
5. TNSS - 1.54 - 7.16 @ 95 - 11.34 @ 117
6. gldelox - 1.725 - 7.4 @ 93.71 - 11.57 @ 117.19
7. Martyjw597-1.52 - 7.35 @ 91.66 - 11.635 @ 115.71
8. theheder - 1.70 - 7.47 @ 92.10 - 11.75 @ 114.27
9. clovisair - 1.68 - 7.669 @ 89.45 - 12.022 @114.15
10. JusticeL20 - 1.68 - 7.65 @ 88.27 -12.062 @ 111.58
11. TBSS instigator - x.xx - 8.128 @ 87.78 - 12.555 @ 112.07
AWD
1. 08HEAVYVETTE 1.614 60'-7.222@95.08-11.315@119.73
2. Juissed - 1.64 - 7.32 @ 93.82 - 11.511 @ 118
3. Jared - 1.708 - 7.466 @ 92.92 - 11.719 @ xx.xx
4. dep - 1.72 - 7.592 @ 91.94 - 11.875 @ 115.20
5. 92tsiawdguy 1.82 - 7.6 @ 90 11.906 @ 114.81
6. swat ss - 1.68 - 7.628 @ 90.07mph - 11.96 @ 111.76mph
7. ssdrooler - 1.733 - 7.656 @ 89.69 - 12.097 @ 110.25
8. justanotherssuv - 1.581 - 7.625 @ 87.77 - 12.114 @ 109.02
9. S10473 - 1.817 - 7.731 @ 90.5 - 12.122 @ 111.88
10. 11 6.2 - 1.75 - 7.86 @ 87.5 - 12.33 @ 110
11. 1SickSS - 1.743 - 7.888 @ 87.98 - 12.369 @ 109.93
12. UrbanSS17 - 1.85 - 8.03 @ 87 - 12.46 @ 109
13. ja93 - 1.696 - 7.929 @ 86.14 - 12.504 @ 106.35
14. 02silver2v - 1.663 - 7.931 @ 85.29 - 12.554 @ 106.32
The Fastest
RWD
1. DBTBSS - 1.43 - 5.83 @ 123.04 - 9.03 @ 151.92
2. RPM x.xx - xx @ xx - 9.06 @ 149
3. FASTLANE x.xx - xx @ xx - 9.561 @ 147.67
4. LaR mUt x.xx - xx @xx - 10.04 @ 135.22
5. TXBlownTBSS - 1.47 - 6.67 @ 102.44 - 10.49 @ 129.38
6. Ronn25 - 1.46 - 6.70 @ 102.55 - 10.514 @ 128.57
7. XMONTE - 1.61 - 6.8 @ 104 - 10.64 @ 129
8. All Ull C - 1.54 - 6.80 @ 101 - 10.66 @ 127
9. thewrx - 1.58 - 8.9 @ 103.21- 10.68 @ 127.2
10. Supermaro - 1.53 - 6.85@99.59 10.70@127.26
11. Dmaxvaz - 1.78 - 7.02 @ 104.29 - 10.78 @ 131.2
12. Rat Raceway - 1.59 - 7.05 @ 99 - 11.02 @ 123
13. freemaSSon - 1.65 - 7.05 @ 98.19 - 11.06 @ 122.17
14. WongBob - 1.484 - 7.030 @ 95.33 - 11.144 @ 119.46
15. suvette_fl - 1.56 - 7.10 @ 95.9 - 11.20 @ 120.49
AWD
1. Inline6 - 1.505 - 6.837 @ 100.40 - 10.736 @ 126.40
2. 1 Fast TB - x.xx - xx @ xx - 10.77@125
3. ForceFed - 1.549 - 6.915 @ 99.90 - 10.838 @ 125.66
4. dave5514 - 1.69 - 7.16 @ 98.3 - 11.15 @ 123.15
5. DocEwww - 1.73 - 7.23 @ 97.80 - 11.22 @ 124.01
6. NEjersey402ss 1.575 - 7.143 @ 95.61 - 11.251 @ 119.56
7. wtb12sec1/4mi- 1.651 - 7.191 @ 96.27 - 11.260 @ 122.02
8. 08HEAVYVETTE 1.614 60'-7.222@95.08-11.315@119.73
9. Buccitbss - 1.652 - 7.31@ 94.47 - 11.45 @ 119.21
10. electricrottweiler - 1.64 - 7.29 @ 93.19 - 11.46 @ 118.71
11. Juissed - 1.64 - 7.32 @ 93.82 - 11.511 @ 118
12. Evil SS 2006 - 1.686 - 7.370 @ 93.947 - 11.52 @ 120.586
13. gn2beatu 1.632 - 7.308 @ 93.56 - 11.546 @ 115.54
14. dom_ls2 - 1.690 - 7.362 @ 93.2 - 11.55 @ 118.13
15. 06SSalltheway - 1.705 - 7.436 @ 93.24 - 11.646 @ 117.35
Jake747 (Aug-06-14), Spivitz (Sep-25-13)
Old Sep-25-13, 03:36 PM   #3
WongBob
High and Tight!!!
WongBob's Avatar
Real Name: Wade
Member # 5354
Like: 38
1. DBTBSS 1.43 - 5.83 @ 123.04 - 9.03 @ 151.92
4. LaR mUt 1.438 - 6.608@103.42 - 10.387 @ 129.92
6. Ronn25- 1.46-6.70@102.55- 10.514@128.57mph
7. XMONTE 1.61 - 6.8@104 - 10.64@129
8. All Ull C - 1.54 - 6.80@101 - 10.66@127
9. Supermaro - 1.53 - 6.85@99.59 10.70@127.26
10. Inline6 - 1.505 - 6.837@100.40 - 10.736 @ 126.40
11. 1 Fast TB 10.77@????
12. Dmaxvaz - 1.78, 7.02@104.29, 10.78 @ 131.2
13. ForceFed 1.549 - 6.915@99.90 - 10.838@125.66
14. Rat Raceway 1.59 - 7.05 @ 99.xx - 11.02 @ 123.xx
15. WongBob - 1.484 - 7.030 @ 95.33 - 11.144 @ 119.46
16. dave5514 - 1.69 - 7.16@98.3 - 11.15 @ 123.15
17. suvette_fl 1.56 - 7.10 @ 95.9 - 11.20 @ 120.49
18. DocEwww - 1.73 - 7.23@97.80 - 11.22@124.01
19. wtb12sec1/4mi 1.651 - 7.191 @ 96.27 - 11.260@122.02
20. devilsown 1.62 - 7.17 @ 95.36 - 11.264 @ 118.79
21. PsRumors 1.628 - 7.223 @ 95.9 - 11.306 @ 120.35
22. J rock - 1.750 - 7.28@97.3 - 11.307@122.4
23. 08HEAVYVETTE 1.614 60'-7.222@95.08-11.315@119.73
24. TNSS 1.54 - 7.16 @ 95 - 11.34 @ 117
25. Buccitbss 1.652 - 7.31 @ 94.47 - 11.45@ 119.21
26. electricrottweiler 1.64 - 7.29 @ 93.19 - 11.46 @ 118.71
27. Juiced - 1.64 - 7.32 @ 93.82 - 11.511 @ 118
28. gn2beatu 1.632 - 7.308 @ 93.56 - 11.546 @ 115.54
29. dom_ls2 1.690 - 7.362 @ 93.2 - 11.55 @ 118.13
30. gldelox 1.725 - 7.4 @ 93.71 - 11.57 @ 117.19
31. Martyjw597-1.52-7.35 @ 91.66 - 11.635 @ 115.71
32. 06SSalltheway 1.705 - 7.436 @ 93.24 - 11.646 @ 117.35
33. Dustin. - 1.65 - 7.448 @ 91.33 - 11.703 @ 116.90
34. mykul 1.68 - 7.42 @ 92.61 - 11.70 @ 114.7
35. 1GMfanatic 1.6 - x.xx @ xx.xx - 11.70 @ 115.0
36. RossiSS 1.66 - 7.46 @ 91.28 - 11.75 @ 115.1
37. theheder - 1.70 - 7.47 @92.10 - 11.75@114.27
38. DirtySS 1.70 - 7.50 @ 92.32 - 11.76 @ 115.41
39. devus1 1.64 - 7.62 @ 90.0 - 11.76 @ 114.xx
40. Blacksheep x.xx - x.xxx @ xx.xx - 11.79 @ 116.xx
41. Jake747 - 1.61 7.49@91.7 11.83@113.17
42. LSX Lover 1.72 - xx @ xx - 11.84 @ 117.79
43. dep 1.72 - 7.592 @ 91.94 - 11.875 @ 115.20
44. tracman466 - 1.65 - 7.56 @ 90.19 - 11.891 @ 113.68
45. 92tsiawdguy 1.82 - 7.6 @ 90 11.906 @ 114.81
theheder (Nov-03-14)
Old Sep-25-13, 03:37 PM   #4
WongBob
High and Tight!!!
WongBob's Avatar
Real Name: Wade
Member # 5354
Like: 38
Left blank for later use.
Old Sep-25-13, 03:43 PM   #5
TNSS
Moderator
TNSS's Avatar
Real Name: Matt
Member # 5229
Casino cash: $523100
Like: 291
Liked 290 Times in 151 Posts
Rep Power: TNSS is a name known to allTNSS is a name known to allTNSS is a name known to allTNSS is a name known to allTNSS is a name known to allTNSS is a name known to all
if anyone's old time fits in the new H/C/I list please let us know and we will add you.
06 2wd TBSS H/C/I 6.0 511/442
1.54 60', 11.34 @ 116.86
Old Sep-25-13, 04:59 PM   #6
martyjw597
martyjw597's Avatar
Real Name: marty
Member # 8397
Casino cash: $1030000
Like: 202
Liked 678 Times in 381 Posts
Rep Power: martyjw597 Gives oral for rep pointsmartyjw597 Gives oral for rep pointsmartyjw597 Gives oral for rep pointsmartyjw597 Gives oral for rep pointsmartyjw597 Gives oral for rep pointsmartyjw597 Gives oral for rep pointsmartyjw597 Gives oral for rep pointsmartyjw597 Gives oral for rep pointsmartyjw597 Gives oral for rep pointsmartyjw597 Gives oral for rep pointsmartyjw597 Gives oral for rep points
Martyjw597 1.664-7.465@ 92.52-11.712@ 115.75
Rwd all motor stock bottom end, all motor, braggin rights.
06 2wd conversion, FLT built trans LT1Z HCI, 12.03 AWD cam only rec. holder. 11.91 2wd cam only, 11.60 and gettin better HCI
Spivitz (Sep-25-13)
Old Sep-25-13, 06:12 PM   #7
PipeDreams
PipeDreams's Avatar
Real Name: Miguel
Member # 14759
Casino cash: $271200
Like: 375
Liked 257 Times in 156 Posts
Rep Power: PipeDreams has a spectacular aura aboutPipeDreams has a spectacular aura about
All Motor RWD
(on the right) http://www.tbssowners.com/forums/att...8&d=1378517586
/ 07 RWD / 408 STROKER / CAM / HEADS / BOLT-ONS / SUSPENSION / 4L80E CONVERSION / E85 / 12.09@114 with 4000' DA on 20's... /
Spivitz (Apr-12-14)
Old Oct-04-13, 12:19 PM   #8
dave5514
dave5514's Avatar
Real Name: Dave
Member # 11589
Casino cash: $139500
Like: 54
Liked 69 Times in 43 Posts
Rep Power: dave5514 is on a distinguished road
Originally Posted by TNSS View Post
Dave if you want your times posted please follow directions we do not have the time to hunt down your time slips for you and try to figure out what class you fall under. if you missed it the directions are In big bold letters in the the first post I will copy and past them here for you.
Sorry Matt,
Sent a PM, wasn't sure how you wanted to receive, but looks like it didn't send! Sorry!
So, here is the info:
dave5514 - 1.69 - 7.16@98.3 - 11.15 @ 123.15 – Fastest AWD and Bragging Rights
5020 race weight
RHS 436 ci / F1R @ 15psi on 93 octane / RPM prepped 4L80e
Again, sorry about that. Time slip was handwritten by track tower, as Compulink slip didn't print. Rodney (GM OR DIE) was there so he can attest to validity if need be.
Thanks much!
Old Oct-05-13, 09:54 PM   #9
PeteG06SS
PeteG06SS's Avatar
Real Name: Pete
Member # 8417
Casino cash: $224600
Like: 125
Liked 115 Times in 76 Posts
Rep Power: PeteG06SS is just really nicePeteG06SS is just really nicePeteG06SS is just really nicePeteG06SS is just really nice
AWD cam only. Full weight 3ss
Sent from my DROID RAZR HD using Tapatalk 2
BigRobSS (Oct-08-13)
Old Oct-14-13, 08:01 AM   #10
tracman466
tracman466's Avatar
Real Name: richard
Member # 20259
Casino cash: $54921
Like: 62
Liked 15 Times in 4 Posts
Rep Power: tracman466 will become famous soon enough
Default I think I set a new record...AWD / all motor
tracman466 - 1.65 - 7.56@90.19 - 11.891@113.68
All wheel drive and All motor
track day weight 5020 1/2-3/4 tank of sunoco 93 full interior plus and driver
416 ls3 stroker with 239 / 255 -.624 lift comp cam,
factory Escalade intake with original throttle body ls7 maf
New Age Hotrods -cold air system and modified oil pan and pickup
Yank 4000 and level6 tranny
ARH headers and SLP exhaust
stock 20" rims with 245/45/20 Hankook summer tires
vehicle is 3 " lowered
DocEwww (Oct-14-13)
Old Oct-14-13, 08:06 AM   #11
Chase
Chase's Avatar
Real Name: Chase
Member # 6940
Casino cash: $1797018
Like: 243
Liked 346 Times in 197 Posts
Rep Power: Chase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep points
Chase 1.845 -7.54@95 -11.655@120.14
RWD "fastest" "bragging rights"
TVS1900 12psi + meth
Factory repo 22's
Full weight
LT1Z blower cam
Built 365 by SAJ racing engines
lvl 5 trans 3,600 yank
2010 CTS-V A6 tune/CAI/upper/lower pulleys/HX/no cats..lowered on 20's. Making 20psi
SOLD!!-TVS1900 12psi 600/594- 2.1 60' 11.65@120 on 22's RWD. FULL WEIGHT 8-rib 10% OD, WCCH heads.,alky control meth kit ,SAJ racing engine,LT1Z cam, LVL 5, Phoenix 3,200, OBX headers,Halo's, FR 20x10, full stereo. I NEED a FOE-FIGH-SICKS
http://www.tbssowners.com/forums/image.php?type=sigpic&userid=6940&dateline=1378924  058
Old Oct-19-13, 05:49 PM   #12
martyjw597
martyjw597's Avatar
Real Name: marty
Member # 8397
Like: 202
Martyjw597:1.52-7.35@91.66-11.635@115.71
H/C/I, stock bottom end, all motor...rwd
Old Oct-26-13, 11:10 AM   #13
92tsiawdguy
92tsiawdguy's Avatar
Real Name: kyle
Member # 18558
Casino cash: $131800
Like: 35
Liked 224 Times in 68 Posts
Rep Power: 92tsiawdguy is just really nice92tsiawdguy is just really nice92tsiawdguy is just really nice92tsiawdguy is just really nice
92tsiawdguy 1.82 60ft 7.6@90mph 11.906@114.81
Awd stock bottom end. no traction
Old Oct-26-13, 04:49 PM   #14
Silverelex
Silverelex's Avatar
Real Name: jason
Member # 3856
Casino cash: $323725
Like: 25
Liked 31 Times in 19 Posts
Rep Power: Silverelex has a spectacular aura aboutSilverelex has a spectacular aura aboutSilverelex has a spectacular aura about
Silverelex 1.73 60' 7.95@86.36 12.48@ 107.56
AWD cam only short belt and rear seat removed on 20s
Sent from my SPH-L710 using Tapatalk 2
2008 Summit White 3SS AWD Kbees,LT1Z cam, Pacesetters,dumped duals,IEATSRT8, flt lvl 6/yank ss3600
1993 Mustang LX- H/C/I, Turbo Time kit, E85-Sold
Old Nov-03-13, 09:41 PM   #15
ALL ULL C
ALL ULL C's Avatar
Real Name: Rich
Member # 1203
Casino cash: $344700
Like: 369
Liked 218 Times in 102 Posts
Rep Power: ALL ULL C is a splendid one to beholdALL ULL C is a splendid one to beholdALL ULL C is a splendid one to beholdALL ULL C is a splendid one to beholdALL ULL C is a splendid one to beholdALL ULL C is a splendid one to beholdALL ULL C is a splendid one to beholdALL ULL C is a splendid one to behold
RWD - Stock bottom end
RWD - The Fastest
RWD - Bragging Rights
http://www.tbssowners.com/forums/showthread.php?t=98867
06' TBSS 2wd - Dart LSNext 388ci/YSi
Old Nov-08-13, 10:34 PM   #16
2FNQUIK
2FNQUIK's Avatar
Member # 4452
Casino cash: $201800
Like: 14
Liked 23 Times in 16 Posts
Rep Power: 2FNQUIK will become famous soon enough2FNQUIK will become famous soon enough
intake and tune only
2FNQUIK-1.747 60'-8.108@84.07-12.756@105.90...slip to follow shortly
Old Nov-12-13, 10:18 AM   #17
XMONTE
XMONTE's Avatar
Member # 1249
Casino cash: $277900
Like: 0
Liked 140 Times in 37 Posts
Rep Power: XMONTE is just really niceXMONTE is just really niceXMONTE is just really niceXMONTE is just really niceXMONTE is just really nice
XMONTE 1.61 6.8@104 10.64@129
408 with BW turbo at 13lbs, AFR 230, Holley intake, LS7 tb, 4L80e, 3600 FTI hard hitter, 2wd, 1SS, full interior, full weight, twin meth nozzle on Hoosier 28" slick...
RWD @ BRAGGING RIGHTS
Sent from my SCH-I535 using Tapatalk
Jake747 (Mar-14-14)
Old Jan-12-14, 07:43 PM   #18
graceliz
graceliz's Avatar
Real Name: Grace
Member # 19336
Casino cash: $73700
Like: 16
Liked 5 Times in 3 Posts
Rep Power: graceliz will become famous soon enough
graceliz - 2.04 - 8.62@81 - 13.37@102 – Intake and Tune Only
http://i207.photobucket.com/albums/b...RD01122014.jpg
2008 RWD 3SS | Custom Tune by SWG | PCM 4" CAI | Transcooler | E-Fans | 160 T-Stat
2008 Chevrolet TrailBlazer SS: 12.840 @ 107.370 MPH
Old Feb-16-14, 11:47 AM   #19
Juissed
Juissed's Avatar
Real Name: Lacie
Member # 1358
Casino cash: $64160
Like: 0
Liked 2 Times in 1 Post
Rep Power: Juissed is on a distinguished road
Juissed - 1.64 - 7.32@93.82 - 11.511@118
stock bottom end, fastest AWD, bragging rights
Race weight 4,995 lbs.
2006 TBSS AWD 11.51@118
TVS1900, Heads, Comp Cam, FLT lvl 7, Yank SC3000
Jake747 (Feb-16-14), Spivitz (Feb-16-14)
Old Mar-07-14, 11:59 AM   #20
11 6.2
11 6.2's Avatar
Real Name: chad
Member # 17108
Casino cash: $401000
Like: 331
Liked 725 Times in 455 Posts
Rep Power: 11 6.2 is a name known to all11 6.2 is a name known to all11 6.2 is a name known to all11 6.2 is a name known to all11 6.2 is a name known to all11 6.2 is a name known to all
11 6.2 1.75-7.86-87.5-12.33-110
AWD stock bottom end.
FBO stock long block, 3200 stall, 150 shot full weight
. SOLD
Ivang79 (Dec-14-14), Jake747 (Mar-14-14)
