LS6 vs our stock intake - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Modifications > Heads/Cam/Intake Manifold/Internals
Heads/Cam/Intake Manifold/Internals Changing Anything In Your LS2??? Let's See It.
Old Feb-01-13, 09:47 AM   #1
TNSS
Moderator
TNSS's Avatar
Real Name: Matt
Member # 5229
Casino cash: $513800
Like: 272
Liked 263 Times in 137 Posts
Rep Power: TNSS is a name known to allTNSS is a name known to allTNSS is a name known to allTNSS is a name known to allTNSS is a name known to allTNSS is a name known to all
Default LS6 vs our stock intake
stock for stock which flows better the LS6 intake or our factory intake. i have looked everywhere but i can not find flow numbers for our stock intake does anyone have them? what about LS6 flow numbers?
06 2wd TBSS H/C/I 6.0 511/442
1.54 60', 11.34 @ 116.86
Sponsored Links
Advertisement
Old Feb-01-13, 09:52 AM   #2
griffincox
griffincox's Avatar
Real Name: Griffin
Member # 11614
Casino cash: $506700
Like: 36
Liked 217 Times in 161 Posts
Rep Power: griffincox is a name known to allgriffincox is a name known to allgriffincox is a name known to allgriffincox is a name known to allgriffincox is a name known to allgriffincox is a name known to all
I believe our intake is the same as all of the 5.3/6.0 truck/SUV. Does anyone know how LS6 and LS2 car differ, if at all? That may help a lot as I bet there are flow numbers for LS2 car and LS truck somewhere.
Old Feb-01-13, 10:11 AM   #3
Grocery Getter
AMSOIL Dealer
Grocery Getter's Avatar
Real Name: Mike
Member # 15957
Casino cash: $586563
Like: 800
Liked 330 Times in 248 Posts
Rep Power: Grocery Getter has a brilliant futureGrocery Getter has a brilliant futureGrocery Getter has a brilliant futureGrocery Getter has a brilliant futureGrocery Getter has a brilliant futureGrocery Getter has a brilliant futureGrocery Getter has a brilliant futureGrocery Getter has a brilliant futureGrocery Getter has a brilliant futureGrocery Getter has a brilliant futureGrocery Getter has a brilliant future
When I bought my ls2 intake (car) for a project I did a little reading. Even though the ls2 intake has a larger (90mm) tb bore, the flow characteristics of the ls6 are/were better. With that being said, the (newer) truck intakes have that same size bore. Our intakes make more power down low, as compared to a car intake that makes its power up high. The ls6 intake makes power higher (in the rpm range) than any of the rest, if I'm not mistaken.
Someone correct me if I'm wrong.......
Originally Posted by ForceFed View Post
I'll continue to stick by my motto.....
Don't Talk about it, Be about it.
Old Feb-01-13, 10:32 AM   #4
Clustertruck
Clustertruck's Avatar
Real Name: Ken
Member # 15263
Casino cash: $117100
Like: 0
Liked 36 Times in 24 Posts
Rep Power: Clustertruck is a splendid one to beholdClustertruck is a splendid one to beholdClustertruck is a splendid one to beholdClustertruck is a splendid one to beholdClustertruck is a splendid one to beholdClustertruck is a splendid one to beholdClustertruck is a splendid one to behold
The flow #s are actually quite interesting, between the two intakes. They are even until .200" valve lift, then the LS6 shows a 10 cfm gain up to .350". From there to .450" lift, the LS6 is 12 cfm better. Then our manifold recovers nicely and stays within a couple cfm until .650" lift, where the LS6 gains 7 cfm, and that's where the test ended. The #s at that point were 256 cfm for our manifold and 263 for the LS6.
I don't have any data on the LS2 vs the LS6, but all the comments I've seen suggest that the LS6 is slightly better, overall.
"Strive for perfection in everything. Take the best that exists and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough." Sir Henry Royce of Rolls-Royce
Old Feb-01-13, 10:42 AM   #5
TNSS
Moderator
TNSS's Avatar
Real Name: Matt
Member # 5229
Like: 272
sweet, now i just need to find a cheap LS6 intake. anyone have one? LOL
Old Feb-01-13, 10:51 AM   #6
ForceFed
ForceFed's Avatar
Real Name: K
Member # 3919
Casino cash: $1905985
Like: 36
Liked 1,521 Times in 657 Posts
Rep Power: ForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep points
Good luck with that. Damn guys think they are gold.
Old Feb-01-13, 10:54 AM   #7
hcblackblazinss
hcblackblazinss's Avatar
Real Name: chris
Member # 9437
Casino cash: $266180
Like: 14
Liked 9 Times in 8 Posts
Rep Power: hcblackblazinss is just really nicehcblackblazinss is just really nicehcblackblazinss is just really nicehcblackblazinss is just really nicehcblackblazinss is just really nice
2nd that!
06 AWD CAM ONLY, RACE PROVEN MOTORSPORTS TUNED
Old Feb-01-13, 10:56 AM   #8
Grocery Getter
AMSOIL Dealer
Real Name: Mike
Member # 15957
Like: 800
Third that!
Cheap and LS6 intake should NEVER go in the same sentence. Unless you're saying they don't go in the same sentence..........
Old Feb-01-13, 11:27 AM   #9
ssam98
ssam98's Avatar
Real Name: ssam
Member # 11904
Casino cash: $626692
Like: 196
Liked 104 Times in 65 Posts
Rep Power: ssam98 is a splendid one to beholdssam98 is a splendid one to beholdssam98 is a splendid one to beholdssam98 is a splendid one to beholdssam98 is a splendid one to beholdssam98 is a splendid one to beholdssam98 is a splendid one to behold
so true.
98 ss camaro 533rwhp, 520rwtq
13 zl1 camaro stock 11.94@117
06 tbss 11.95@115 stock every thing with 1900tvs
Old Feb-01-13, 12:38 PM   #10
TNSS
Moderator
TNSS's Avatar
Real Name: Matt
Member # 5229
Like: 272
ya im seeing that, man 450 for a used intake. that is stupid a new one probably isn't much more.
Old Feb-01-13, 12:57 PM   #11
Chase
Chase's Avatar
Real Name: Chase
Member # 6940
Casino cash: $1783518
Like: 232
Liked 331 Times in 184 Posts
Rep Power: Chase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep points
It's the vette guys! They think their cars worth way more than it really is.
2010 CTS-V A6 tune/CAI/upper/lower pulleys/HX/no cats..lowered on 20's. Making 20psi
SOLD!!-TVS1900 12psi 600/594- 2.1 60' 11.65@120 on 22's RWD. FULL WEIGHT 8-rib 10% OD, WCCH heads.,alky control meth kit ,SAJ racing engine,LT1Z cam, LVL 5, Phoenix 3,200, OBX headers,Halo's, FR 20x10, full stereo. I NEED a FOE-FIGH-SICKS
http://www.tbssowners.com/forums/image.php?type=sigpic&userid=6940&dateline=1378924  058
Old Feb-01-13, 12:59 PM   #12
Alvin
Tuner at PCMofnc.com
Alvin's Avatar
Real Name: Alvin
Member # 220
Casino cash: $542200
Like: 0
Liked 8 Times in 7 Posts
Rep Power: Alvin has much to be proud ofAlvin has much to be proud ofAlvin has much to be proud ofAlvin has much to be proud ofAlvin has much to be proud ofAlvin has much to be proud ofAlvin has much to be proud ofAlvin has much to be proud ofAlvin has much to be proud of
What are you using it for Matt? I think a car 102 upper and runners will fit your LSXRT
PCMofNC.com PCM of NC, INC - 704-307-4227
Old Feb-01-13, 01:18 PM   #13
TNSS
Moderator
TNSS's Avatar
Real Name: Matt
Member # 5229
Like: 272
Im going to be using it on my junkyard dog L33 5.3 swap turbo build in a gen 3 camaro
Old Feb-01-13, 01:35 PM   #14
Clustertruck
Real Name: Ken
Member # 15263
Like: 0
I'm using an Edelbrock Victor Jr and am very pleased with it. It could be a great fit for your turbo application! It flows 24 more cfm, compared to the LS6, @ .500" valve lift. The manifold is only around $340 new, but you'll need some type of elbow, of course. It's a racier piece and certainly would have performance advantages over the LS6, though it would give up some low end. Might be worth investigating.
Old Feb-01-13, 01:45 PM   #15
1FAST07SS
1FAST07SS's Avatar
Real Name: Brian
Member # 7652
Casino cash: $683975
Like: 159
Liked 257 Times in 188 Posts
Rep Power: 1FAST07SS is a jewel in the rough1FAST07SS is a jewel in the rough1FAST07SS is a jewel in the rough1FAST07SS is a jewel in the rough
What about a ported stocker from peak speed? Would that not flow better than the ls6 and be comparable to the edelbrock intake?
2007 AWD| Forged 402 | AFR heads | FAST LSXRT | RPM level V | kooks 1 3/4 with ory/cats |PCM 4" FWI/LS7MAF | pcmforless transcooler | efans | circle D 3200 | R1 slotted rotors | SS braided brake lines |
Old Feb-01-13, 01:45 PM   #16
PRAY
Real Name: Brett
Member # 15812
Casino cash: $117900
Like: 0
Liked 10 Times in 8 Posts
Rep Power: PRAY is an unknown quantity at this point
I know you have stated in other threads that you only flow manifolds attached to a head. For your stated results above what was the CFM of the heads you flowed the manifolds on? I am also curious to know if you have seen the flow of an intake increase with the flow of a head? In theory a manifold would only be able to flow so much air no matter what is pulling on it. But in practice, better heads make more power with the same intake attached. That could be soley due to CFM gains at lower valve lifts under the peak flow of the intake manifold since the manifolds flow is not dictated by valve lift, only flow capability of the runner. I would like to know if you have any data backing either up. I think it would help in head selection or head porting options is one is inclined to port their own heads. Because, if an intake can only flow 256cfm then what is the point of a head under it that can flow 300cfm? I remember working with Brian Tooley about fourteen years ago on this with a L98 SuperRam and Miniram on a set of AFR 210's but I can't remember what we came up with.
02 Z06 N/A 416 573/530rw 10.21@136.12. Sold
06' Silverado L33 5.3 ECRB. 330/325rw. Sold.
07' TBSS 2WD BER H/C/I/E Stalled 455/420rw. Sold.
Old Feb-01-13, 01:47 PM   #17
TNSS
Moderator
TNSS's Avatar
Real Name: Matt
Member # 5229
Like: 272
do you have a part number? ill check it out, but im really trying to stay cheap. my buddy bought a LS6 for $50 but i cant find anything like that, he is a lucky sucker LOL.
Old Feb-01-13, 01:52 PM   #18
PRAY
Real Name: Brett
Member # 15812
Like: 0
I might be able to find you an LS6. Let me email a buddy of mine.
I think it was Matt or some one else on here in the FI section that was against the Vic jr. for FI. Uneven distirbution I believe. The middle four runners end up lean and the outer's end up fat. I think the posted in my turbo build thread.
Old Feb-01-13, 01:58 PM   #19
TNSS
Moderator
TNSS's Avatar
Real Name: Matt
Member # 5229
Like: 272
let me know what you find out. thanks
Old Feb-01-13, 02:01 PM   #20
PRAY
Real Name: Brett
Member # 15812
Like: 0
Sorry man, my guy just said the same thing you are saying $350-400 they are in VERY high demand. We stopped using them as cores for porting due to the cost.
