Cold weather effect tranny?? Soft 1-2 shift - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Drivetrain > 4L70E Transmission Help
4L70E Transmission Help Tranny Info and Upgrades including torque converters (stall)
Old Oct-29-12, 06:11 PM   #1
11 6.2
11 6.2's Avatar
Real Name: chad
Member # 17108
Casino cash: $393100
Like: 313
Liked 695 Times in 436 Posts
Rep Power: 11 6.2 is a name known to all11 6.2 is a name known to all11 6.2 is a name known to all11 6.2 is a name known to all11 6.2 is a name known to all11 6.2 is a name known to all
Default Cold weather effect tranny?? Soft 1-2 shift
In FL we got a 20* drop in temps the last 2 days, cuz of it I drove my hot rod yesterday and tomorrow.
Got in the TBSS tonight, started it, let it warm up in my driveway, then headed out. Pulled onto the highway and gave it a nice romp in 1st and had a very soft shift into 2nd and I got on it a few times after not WOT and the 1-2 seems a lil soft. The rest of the gears seemed fine and at part throttle it seems fine.
Could the weather be effecting it or do I need to start lookin for shops to build my tranny?
Sponsored Links
Advertisement
Old Oct-29-12, 06:13 PM   #2
Chase
Chase's Avatar
Real Name: Chase
Member # 6940
Casino cash: $1782618
Like: 232
Liked 331 Times in 184 Posts
Rep Power: Chase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep pointsChase Gives oral for rep points
hmmm.. idk what would cause that.. al i know is my truck love's this WEATHER!!
2010 CTS-V A6 tune/CAI/upper/lower pulleys/HX/no cats..lowered on 20's. Making 20psi
SOLD!!-TVS1900 12psi 600/594- 2.1 60' 11.65@120 on 22's RWD. FULL WEIGHT 8-rib 10% OD, WCCH heads.,alky control meth kit ,SAJ racing engine,LT1Z cam, LVL 5, Phoenix 3,200, OBX headers,Halo's, FR 20x10, full stereo. I NEED a FOE-FIGH-SICKS
http://www.tbssowners.com/forums/image.php?type=sigpic&userid=6940&dateline=1378924  058
Old Oct-29-12, 06:14 PM   #3
OMGTruk
Member # 16222
Casino cash: $144400
Like: 0
Liked 17 Times in 12 Posts
Rep Power: OMGTruk is on a distinguished road
check the fluid level?
Winter White 9-7x
Old Oct-29-12, 07:25 PM   #4
mrinken
SS = TOW PIG
mrinken's Avatar
Real Name: Matt
Member # 10112
Casino cash: $632800
Like: 698
Liked 682 Times in 354 Posts
Rep Power: mrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant future
I wouldn't send it straight to the shop... Does it continue to do it once the transmission is warm?
Old Oct-29-12, 07:59 PM   #5
11 6.2
11 6.2's Avatar
Real Name: chad
Member # 17108
Like: 313
Thanks for the info guys. I haven't hammered it since it did it the first time but after driving around for a little bit and rly paying attention it seems to be a little soft 1-2 even at part throttle. When I got home after a little trip in 3 gear to get it warmed up I checked the fluid with it running in park and the line was at the top of the "cold" mark. So now I'm wondering if that's the problem but that also makes me wonder why it's low if that is the case.
Old Oct-30-12, 06:37 AM   #6
mrinken
SS = TOW PIG
mrinken's Avatar
Real Name: Matt
Member # 10112
Like: 698
If the transmission is completely warmed up, it needs to be filled to the "hot" mark. Otherwise, a soft weird 1-2 shift sounds like accumulator piston.
Old Oct-30-12, 01:39 PM   #7
11 6.2
11 6.2's Avatar
Real Name: chad
Member # 17108
Like: 313
Quart low on fluid is what the problem was. Now my ? is why is it all of the sudden low on oil?? Air pocket from when my TC was installed??
Old Oct-30-12, 01:43 PM   #8
OMGTruk
Member # 16222
Like: 0
when was the converter put in? i've put them in and thought everything was good fluid wise only to come back after a trip around the block and have it next to empty.
is everything tight and dry underneath? no drips from the cooler lines, vent, etc?
Winter White 9-7x
Old Oct-30-12, 02:20 PM   #9
CHEVY6000TBSS
CHEVY6000TBSS's Avatar
Real Name: Jim
Member # 5798
Casino cash: $1262370
Like: 94
Liked 489 Times in 375 Posts
Rep Power: CHEVY6000TBSS Gives oral for rep pointsCHEVY6000TBSS Gives oral for rep pointsCHEVY6000TBSS Gives oral for rep pointsCHEVY6000TBSS Gives oral for rep pointsCHEVY6000TBSS Gives oral for rep pointsCHEVY6000TBSS Gives oral for rep pointsCHEVY6000TBSS Gives oral for rep pointsCHEVY6000TBSS Gives oral for rep pointsCHEVY6000TBSS Gives oral for rep pointsCHEVY6000TBSS Gives oral for rep pointsCHEVY6000TBSS Gives oral for rep points
Maybe the engine borrowed some fluid..............It may have a "Low T" diagnoses and is just embarrassed to tell anyone.
J
2008 AWD 3SS TBSS
Black on Black
PCMofNC One piece CAI kit w/ LS7 MAF/ Boltonspeed FWI shield/ PCMofNC Trans Cooler with E-fan/ PCMofNC 3 Cable Battery Kit/ LC32 Black Billet water pump nut/ PCMofNC Dual Spal fans with 3 Relay Harness & Gen 3 fan shroud/ Taylor Thundervolt 50 wires/ NGK TR6IX Plugs/ TRS 6K Headlight Retro fit and Blue Demon Lights done by JDSS/ TRS 6K fogs/ Fog light Housing Mod/ DRL Capacitor Mod/ MCV Overlays/ Areoforce v2/ Tuned by Speedmaster747
Old Oct-30-12, 02:47 PM   #10
OMGTruk
Member # 16222
Like: 0
J
Winter White 9-7x
Old Oct-30-12, 06:17 PM   #11
Vince B
Transmission Specialist
Vince B's Avatar
Real Name: Vince B
Member # 1743
Casino cash: $85232
Like: 0
Liked 0 Times in 0 Posts
Rep Power: Vince B has a spectacular aura aboutVince B has a spectacular aura aboutVince B has a spectacular aura about
I always fill units to the low side of the hot hash marks or just below when cold. These units don't mind a little extra oil. For years this 4l6..... platform never had a cold and hot range of hash marks. Not sure why they went this but the only thing I have seen from it is you guys not having enough fluid in the trans because of it. If you are a half inch or inch over the top of full hot side of the marks don't be alarmed you will be fine. Now if your 2-3 inches over its going to puke it out the vent sooner or later which is not a good thing. I always recommend this when guys question fluid levels and its never let me down! Best of luck. Vince
Old Oct-31-12, 05:12 AM   #12
11 6.2
11 6.2's Avatar
Real Name: chad
Member # 17108
Like: 313
Thanks for the comments guys!! I checked underneath and no leaks or any wet spots, the guy who did the TC seemed to think there was an air pocket. He told me the same info Vince just said about the fluid level and told me to get the level a little above the full mark. Everything seems to be fine now but I'm gonna start puttin money aside to get it built before it blows on me.
Old Oct-31-12, 08:28 PM   #13
TmanSC07TBSS
TmanSC07TBSS's Avatar
Real Name: Wylie T.
Member # 9846
Casino cash: $927700
Like: 55
Liked 33 Times in 27 Posts
Rep Power: TmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant future
Fluid low will do it for sure, but cold weather is hard on a Tranny and a Motor is you get on it.
[07 Black 3SS ; Maggie 2300, Built 4L85e Trans, SW Hdrs w/True SW Duals, CAI, LS1 Efans, Custom Seat Inlays & Dash Bezel, D&S Rtrs, Keystone Hood, Cativo 20"wheels, Lowered, Pioneer DVD, Tinted Bermuda Tails, PCMofNC Dyno Tune and much more.
