Tire Pressure Inaccurate - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Suspension/Tires/Brakes/Other > Wheels/Tires
Wheels/Tires Anything Dealing with Above
Old Oct-20-12, 07:56 PM   #1
JJAY374
JJAY374's Avatar
Real Name: Jason
Member # 17527
Casino cash: $53700
Like: 0
Liked 0 Times in 0 Posts
Rep Power: JJAY374 is an unknown quantity at this point
Default Tire Pressure Inaccurate
So my right front shows on dash that I am at 25 PSI.. But when I manually check it with digital gauge it shows 40. I used different pressure gauges to make sure it wasn't my gauge. Do you all think its a bad sensor? Or is there a way to reset it? Any info would be great... It's for 2006 2SS thanks!
Sponsored Links
Advertisement
Old Oct-20-12, 08:05 PM   #2
jrSS
jrSS's Avatar
Real Name: Jeff
Member # 16758
Casino cash: $303600
Like: 177
Liked 223 Times in 154 Posts
Rep Power: jrSS has much to be proud ofjrSS has much to be proud ofjrSS has much to be proud ofjrSS has much to be proud ofjrSS has much to be proud ofjrSS has much to be proud ofjrSS has much to be proud ofjrSS has much to be proud of
Bad sensor.
Old Oct-20-12, 08:32 PM   #3
GrannysTBSS
Retired USAFR
GrannysTBSS's Avatar
Real Name: Angelo
Member # 3392
Casino cash: $97395
Like: 81
Liked 5 Times in 5 Posts
Rep Power: GrannysTBSS has a spectacular aura aboutGrannysTBSS has a spectacular aura aboutGrannysTBSS has a spectacular aura about
Originally Posted by jrSS View Post
Bad sensor.
Um yes, bats do GO bad.......................
Its 2012 so it get-in close to a change out.
Old Oct-20-12, 09:22 PM   #4
JJAY374
JJAY374's Avatar
Real Name: Jason
Member # 17527
Casino cash: $53700
Like: 0
And I know 40PSI seems like a lot for what it reads but at my altitude it's needed... Plus the f'ing cold air this place has lol... So time to replace sensor...
Old Oct-20-12, 10:23 PM   #5
123garren
123garren's Avatar
Real Name: Garren
Member # 12926
Casino cash: $94997
Like: 0
Rep Power: 123garren is on a distinguished road
A couple of things u r going to find out their is no 2ss only a 1ss and 3ss with and without different options. And sounds lije a bad sensor. U might also think about no2.
ECM TCM tuned by Vector motorsports, CAI, tinted tails,mostly stock.
Old Oct-22-12, 01:49 AM   #6
Turbizzy
Turbizzy's Avatar
Real Name: Izzy
Member # 6
Casino cash: $113300
Like: 3
Liked 2 Times in 2 Posts
Rep Power: Turbizzy has a spectacular aura aboutTurbizzy has a spectacular aura about
Just wanted to comment on this. Couple days ago after filling up gas and pulling out the gas station, my TPMS light came on and CHECK TIRE PRESSURE warning came on the cluster. After switching through the tire pressure readings all were close to 40 except right front said I was at 4 psi! So I quickly pulled over to check the tire and to my confusement it looked fine to me and didn't seem flat enough for 4 psi. So restarted the truck and took off, couple mins later light went off and pressure was now reading 39psi wtf lol.
Izzy
Old Oct-22-12, 11:30 AM   #7
06WhiteSS
Resident Asshole!
06WhiteSS's Avatar
Real Name: Chad
Member # 642
Casino cash: $464267
Like: 0
Rep Power: 06WhiteSS Gives oral for rep points06WhiteSS Gives oral for rep points06WhiteSS Gives oral for rep points06WhiteSS Gives oral for rep points06WhiteSS Gives oral for rep points06WhiteSS Gives oral for rep points06WhiteSS Gives oral for rep points06WhiteSS Gives oral for rep points06WhiteSS Gives oral for rep points06WhiteSS Gives oral for rep points06WhiteSS Gives oral for rep points
ETR2
There was none of these in 06.... SS wasn't a model option, but a package you selected on either,an LS or LT. Hence the LS/SS or LT/SS.
Sent from my SAMSUNG-SGH-I727 using Tapatalk
2000 Camaro SS- Sold; 2006 TBSS LT AWD- K&N FIPK, DJM Upper A Arms, Belltech Lowering Struts, Slow, 30" on all four corners.....- Sold!!!
2007 Chevy Tahoe LTZ- All options except retractable running boards....
