PAC Delco F63 Filter - Anyone using instead of a PF48? - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Modifications > Trailblazer SS Engine Related Questions/Info
Old Sep-24-11, 08:41 AM   #1
02xtreme07SS
Real Name: Jim
Member # 1076
Casino cash: $777125
Like: 275
Liked 202 Times in 113 Posts
Rep Power: 02xtreme07SS has much to be proud of02xtreme07SS has much to be proud of02xtreme07SS has much to be proud of02xtreme07SS has much to be proud of02xtreme07SS has much to be proud of02xtreme07SS has much to be proud of02xtreme07SS has much to be proud of02xtreme07SS has much to be proud of
Default AC Delco F63 Filter - Anyone using instead of a PF48?
After Forcefed brought up the 06 and 07-09 difference in filters yesterday, PF46 v PF48, I was doing a little looking around and came up with a new for 2011, PF63 (GM 89017525). The PF63 is now being used in place of the PF48 in some applications, specifically the Traverse/Acadia and CTS. On the surface, the only difference appears to be the height. The PF63 is an inch longer. HOWEVER...I've found varying degrees of internal differences across cross referencing some other brands. The most significant difference on the surface being the relief valve settings.
Here's a pic of the height difference between them.
Here are the specs that were listed on another site:
The relief valve settings are different.
PH63: 9-15 psi
PF48: 9-12 psi
The only other difference is the height.
PF63: 4.06 inches
PF48: 3.33 inches
PF63
Product Type Full-Flow Lube Spin-on
Anti-Drain Valve YES
Gasket I.D. 2.45"
Gasket O.D. 2.76"
Gasket Usage Base
Product Height 4.06"
Product I.D. 22mmx1.5mm Th'd
Product O.D. 2.98"
Relief Valve Setting PSI 9-15
PF48
Gasket I.D. 2.45"
Gasket O.D. 2.76"
Gasket Thickness .19"
Gasket Usage Base
Product Height 3.33"
Product O.D. 3"
Relief Valve Setting PSI 9-12
I run K&N filters (HP-1017) so I looked up what they have listed, but I had to cross the Delco to a Fram and then to a K&N. The relief valve settings are identical on the K&N's, along with many of the other specs with the exception of the height. Again, more research is going to be needed as there could be some other internal, media, filtration, etc, etc, differences that may not allow the longer PF63 and it's cross referenced filters to be used, but this may at least give some of you a lead on a longer filter for your 07 and up. Maybe one of our GM Parts guys (ahem...Greg) can verify some of the information here and see if we can use this filter. Honestly, I don't even know if it will clear the crossmember below the filter right now, I'd have to go look.
Part HP-2011 Product Specifications
Product Style: Oil Filters
Height: 4.78 in (121 mm)
Outside Diameter: 3.01 in (76 mm)
Thread Inside Diameter: M22 x 1.5 Special Thread
PSI Relief Valve: 11-17
Anti Drain Back Valve: Yes
Style: Canister
Removal Nut: Yes
Gasket Material: Nitrile Rubber
Filter Material: High Flow Premium Media
Bypass Valve: Yes
Weight: 0.9 lb (0.41 kg)
Product Box Length: 3.13 in (79 mm)
Product Box Width: 3.13 in (79 mm)
Product Box Height: 5.75 in (146 mm)
Compared to filter I normally run:
Part HP-1017 Product Specifications
Height: 3.75 in (95 mm)
Outside Diameter: 3 in (76 mm)
Thread Inside Diameter: M22x1.5
Thread Number: 1.5
Style: Canister
Removal Nut: Yes
Bypass Valve: Yes
This Product Includes: 26-30930 Gasket
Weight: 0.79 lb (0.36 kg)
Product Box Length: 3.16 in (80 mm)
Product Box Width: 3.16 in (80 mm)
Product Box Height: 4 in (102 mm)
Disclaimer: I'm just gathering some info in the event that this might work, I'm not telling you to go out and throw one on your truck. I assume no responsibility for the above information being correct as it was pulled from various sites on the web, I'm just putting it in one place so you can make your own decision and do your own research.
07 TBSS AWD 3SS (Black) - 09 TBSS 2WD 3SS (Silver)
Sponsored Links
Advertisement
Old Sep-24-11, 08:45 AM   #2
ForceFed
ForceFed's Avatar
Real Name: K
Member # 3919
Casino cash: $1909785
Like: 46
Liked 1,529 Times in 661 Posts
Rep Power: ForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep pointsForceFed Gives oral for rep points
If its like my truck...Id never be able to get that filter in with the crossmember below the oil pan.
Its a tight fit already.
Old Sep-24-11, 08:49 AM   #3
02xtreme07SS
Real Name: Jim
Member # 1076
Like: 275
That's what I was kind of worried about without even looking. Thanks for confirming.
Old Sep-24-11, 08:51 AM   #4
ForceFed
ForceFed's Avatar
Real Name: K
Member # 3919
Like: 46
It might go....But It would be tight.
Old Sep-24-11, 09:00 AM   #5
Lilkickerdude
Lilkickerdude's Avatar
Member # 9314
Casino cash: $180335
Like: 0
Liked 0 Times in 0 Posts
Rep Power: Lilkickerdude is on a distinguished road
what if you get Joe's cross member will it fit then? i ran the larger filter on denali it would be great to run a bigger on these pigs
2008 TBSS Summit White 2WD (GONE...) - tinted, CAI, 160 TStat, Kooks, Circle D 3200, PCMforless Trans cooler, LS1 Efans, LC32 tuned, 6k HIDs, PB 1/4 ET: 13.58
2006 STS-V Black Raven
Old Sep-24-11, 09:05 AM   #6
02xtreme07SS
Real Name: Jim
Member # 1076
Like: 275
Curiosity got the best of me so I went into the garage to look...got some pics of the filter on my '09. Might be a struggle to get the longer one in there, especially if you pre-fill filters. From the nut on the bottom of my K&N to the cross member I have about 1 5/8". From the bottom of the actual canister to the cross member I get 2". Pics below.
Nut to cross member:
Canister to cross member:
Old Sep-24-11, 05:06 PM   #7
DVelasco68
DVelasco68's Avatar
Real Name: David
Member # 469
Casino cash: $365800
Like: 0
Liked 9 Times in 9 Posts
Rep Power: DVelasco68 is a jewel in the roughDVelasco68 is a jewel in the roughDVelasco68 is a jewel in the roughDVelasco68 is a jewel in the rough
dvelasco68
It should definitely fit then, since we're only talking about an additional 1/4" beyond the nut on the K & N oilf filter...
2007 AWD Summit White - 3SS (13.74@100.31) - daily driver
1987 T-Type (12.10 @ 111.5) - in the garage
1986 Grand National (13.29 @ 101.5) - stolen
Old Sep-25-11, 09:26 AM   #8
ssprince
The Lurker
ssprince's Avatar
Real Name: Anthony
Member # 1369
Casino cash: $1328200
Like: 4
Liked 115 Times in 75 Posts
Rep Power: ssprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant future
Brand new RPM Trans....Broke with under 8K miles...No warranty or help.
Old Sep-25-11, 09:41 AM   #9
ForceFed
ForceFed's Avatar
Real Name: K
Member # 3919
Like: 46
Get out of here with your nonsense.
Theere would be plenty of those around if Billy Finished what he started.
Old Sep-25-11, 10:20 AM   #10
ssprince
The Lurker
ssprince's Avatar
Real Name: Anthony
Member # 1369
Like: 4
Yeah I know......sry Bud, I'm glad I got mine when I did...I bought mine from a member that never installed it!
Old Sep-29-11, 09:21 AM   #11
NORCAL SS
LT1Z CHOPOVICH CAM
NORCAL SS's Avatar
Real Name: Tony
Member # 1
Casino cash: $2257261
Like: 3
Liked 776 Times in 355 Posts
Rep Power: NORCAL SS has disabled reputation
c6 oil pan with joes crossmember you can do it.
Your one stop shop for all Trailblazer Suspension/Wheels www.tbssowners.com/store
Have any TBSS Questions? I'm Free to help 24/7 give me a call/text at 415 519 2432 or email me at tony@tbssowners.com
WWW.CTSVOWNERS.COM #1 DEDICATED FORUM FOR THE CADILLAC CTSV
Old Sep-29-11, 09:56 AM   #12
TWO-TONS-OF-FUN
Moderator
TWO-TONS-OF-FUN's Avatar
Real Name: Greg
Member # 1248
Casino cash: $1997662
Like: 18
Liked 164 Times in 49 Posts
Rep Power: TWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep points
c6 pan with no crossmembers... NOT happening.. lol.
Old Oct-01-11, 03:51 PM   #13
02xtreme07SS
Real Name: Jim
Member # 1076
Like: 275
I changed the oil in both SS's today and I really don't think I would have been able to get a longer filter in there with the stock cross member. Even with the normal length filter it takes a little finesse to get it position, so any additional length might be a deal breaker. I did not try to use the longer filter, I just don't think it will fit after today. Sorry if I got anyone's hopes up.
Old Oct-03-11, 07:49 AM   #14
07trail
07trail's Avatar
Member # 9205
Casino cash: $117400
Like: 0
Liked 7 Times in 5 Posts
Rep Power: 07trail is on a distinguished road
If that PF63 is the same length as a PF61 it will fit. On my Avalanche I upgraded to the PF61 and thought I would try it on the SS it fit and all but just wrong thread size by a cunt hair and it wasn't bad to get it in there a little more snug but not like you had to get a bunch of tools out and rework the thing.
07' Trailblazer 1SS 2WD, 3.42 gears, CAI, Electric fans (soon)
Old Oct-03-11, 07:50 AM   #15
02xtreme07SS
Real Name: Jim
Member # 1076
Like: 275
PF61 is 3/4" shorter than a PF63.
Old Oct-03-11, 08:35 AM   #16
RJA
RJA's Avatar
Real Name: Ryan
Member # 11766
Casino cash: $282101
Like: 0
Liked 1 Time in 1 Post
Rep Power: RJA is just really niceRJA is just really niceRJA is just really niceRJA is just really nice
Are the tests on the HP filters showing good results & build quality so far? I havent looked into the threads on them yet. I buy a few of them when they go on sale.
Old Oct-03-11, 10:32 AM   #17
07trail
07trail's Avatar
Member # 9205
Like: 0
Then I would have to say negative ghost rider on the question of it fitting.
Old Oct-08-11, 02:53 PM   #18
DVelasco68
DVelasco68's Avatar
Real Name: David
Member # 469
Like: 0
dvelasco68
I definitely fits.... Not even a squeeze... You go in diagonally and whalla..
I used i a NAPA 7045 Gold (wix) filter which is the equivalent (if not better than) PF63...
I figured I'd use this, since I haven't had the money to put on the modified AWD oilpan, and side oiler kit... I just paid 7K for azek (like trex) decking, which I'm installing in place of my wood decking... Also I just paid 6K for my daughter's braces, and 3K on my wife's minivan for a head gasket job, and complete A/C R&R (compressor, condensor, etc..) needless to say funds aren't there for the TBSS...
Old Oct-08-11, 04:43 PM   #19
DVelasco68
DVelasco68's Avatar
Real Name: David
Member # 469
Like: 0
dvelasco68
went for a ride, and noticed that the wix flows a decent amount more than the Purolator Premium one does...
At idle the P1 (PF48) was 36 PSI oil Pressure, now with the Napa gold (7045) it's 40 PSI...
Old Oct-13-11, 05:33 PM   #20
UrbanSS17
UrbanSS17's Avatar
Real Name: Brian
Member # 5729
Casino cash: $693892
Like: 471
Liked 805 Times in 508 Posts
Rep Power: UrbanSS17 has much to be proud ofUrbanSS17 has much to be proud ofUrbanSS17 has much to be proud ofUrbanSS17 has much to be proud ofUrbanSS17 has much to be proud ofUrbanSS17 has much to be proud ofUrbanSS17 has much to be proud ofUrbanSS17 has much to be proud ofUrbanSS17 has much to be proud ofUrbanSS17 has much to be proud of
Changed my oil today as well. Before change with the k&n my oil psi was 34-36 at idle. After change and the big wix filter I'm closer to 40 psi. After getting it up to temp id say the psi is the same. Plenty of room for the bigger filter. Slid right in like it belongs there.
