4L80E shift linkage?? - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Drivetrain > 4L70E Transmission Help > 4L80E/4L85E
Old Jul-04-11, 07:56 PM   #1
XplicitPerformance
XPTBSS
Real Name: Dru
Member # 2416
Casino cash: $545900
Like: 0
Liked 7 Times in 7 Posts
Rep Power: XplicitPerformance is a splendid one to beholdXplicitPerformance is a splendid one to beholdXplicitPerformance is a splendid one to beholdXplicitPerformance is a splendid one to beholdXplicitPerformance is a splendid one to beholdXplicitPerformance is a splendid one to beholdXplicitPerformance is a splendid one to behold
Default 4L80E shift linkage??
Okay we got the tranny stabbed, the driveshaft modified and installed, the 80E trans file is loaded but I can't get the shift linkage figured out. What are you guys doing and are you running the 70E bracket or the 80E bracket?
Pics would be helpful if you got em!
XPTBSS - cam only 80E beast! RIP
XPTBSS v2 - SOLD!
XP G8 - Procharged G8 GT (wifes)
Sponsored Links
Advertisement
Old Jul-04-11, 09:13 PM   #2
tbssinmass
tbssinmass's Avatar
Real Name: donny
Member # 8181
Casino cash: $422692
Like: 19
Liked 74 Times in 39 Posts
Rep Power: tbssinmass is a jewel in the roughtbssinmass is a jewel in the roughtbssinmass is a jewel in the rough
zipties?
Old Jul-04-11, 09:47 PM   #3
XplicitPerformance
XPTBSS
Real Name: Dru
Member # 2416
Like: 0
I would prefer to have an actual bracket but thanks for the help anyways.
XPTBSS v2 - SOLD!
Old Jul-05-11, 01:04 PM   #4
Greg Ducato
Real Name: Greg
Member # 2169
Casino cash: $252400
Like: 3
Liked 53 Times in 26 Posts
Rep Power: Greg Ducato is just really niceGreg Ducato is just really niceGreg Ducato is just really niceGreg Ducato is just really nice
Use the bracket from a 2000-2008 Chevy 3/4 ton or one ton gas engine. Your stock cable goes right into it. Use the MLPS and the shifter linkage from your 4L70E.
Old Jul-05-11, 03:50 PM   #5
XplicitPerformance
XPTBSS
Real Name: Dru
Member # 2416
Like: 0
Thanks Greg. What is MLPS though?
I got all the lines fixed up and it seems one of the transmission fittings is leaking. If I am not mistaking these 97+ 4L80E's have self sealing fittings correct? I am going to have to replace it.
XPTBSS v2 - SOLD!
Old Jul-06-11, 07:09 AM   #6
Greg Ducato
Real Name: Greg
Member # 2169
Like: 3
The MLPS is the "manual lever position sensor" which is located on the drivers side case/linkage and is sometimes referred to as a neutral safety switch. Late 4L80e's have an internal o-ring in the stock cooler fitting like the 4L70E does
Old Jul-06-11, 10:36 AM   #7
XplicitPerformance
XPTBSS
Real Name: Dru
Member # 2416
Like: 0
Ahh okay thanks Greg. It ended up being a worn tranny fitting on the 80E that was causing the leak. I picked one up at the local stealership who stuck it to me and sent me on my way for 17$ for one fitting Going to focus on the wiring part today and pick up the shifter linkage bracket. Should be rolling by the weekend assuming all goes well.
XPTBSS v2 - SOLD!
Old Jul-09-11, 10:21 AM   #8
XplicitPerformance
XPTBSS
Real Name: Dru
Member # 2416
Like: 0
Well we got it all together and I re-pinned the harness and that was a breeze. Definitely worth the money saved from buying the 200$ harness. Wired in the extra speed sensor as well. Had the shift linkage cable rip so I will be replacing that. I have my tuner coming over this week to handle the chores. I sure love having a tuner who will make house calls.
XPTBSS v2 - SOLD!
Old Jul-09-11, 10:37 AM   #9
speedmaster747
The Legend!
speedmaster747's Avatar
Real Name: Luis
Member # 1497
Casino cash: $910550
Like: 7
Liked 15 Times in 14 Posts
Rep Power: speedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep points
Let me know how it runs with it....
Custom modifications at awesome prices (Cam swaps, tunes, Scheduled maintenance) hit me up on a PM for more info
Old Jul-09-11, 04:58 PM   #10
jakebdb56
Real Name: Jake
Member # 12511
Casino cash: $51800
Like: 0
Liked 0 Times in 0 Posts
Rep Power: jakebdb56 is an unknown quantity at this point
Drove it earlier, runs great. Dru is out driving it around right now getting some heat cycles through it
Old Jul-09-11, 07:32 PM   #11
XplicitPerformance
XPTBSS
Real Name: Dru
Member # 2416
Like: 0
Runs pretty well. You can definitely tell the difference in the gearing. I made one wide open hit and it feels a little better on the big end. Over all I am pretty happy with it. The 80E swap kit we put together was awesome and worked great. So for any 2008 models that need any help feel free to PM me.
I would like to think Zach with Daily Grind Fabrication for the very well built crossmember. I would also like to think Jake from BrownSpeed for the wiring help as well as the tuning chores. Also need to think greg at phoenix for setting me up with one of his awesome converters. It feels great! We got it done when others said we couldn't and that makes it that much sweeter!
XPTBSS v2 - SOLD!
Old Jul-20-11, 07:44 AM   #12
99kon
99kon's Avatar
Real Name: Ramon
Member # 12119
Casino cash: $116200
Like: 0
Rep Power: 99kon is an unknown quantity at this point
Good deal Dru
Ill be doing this to mine also here shortly. Mine is an 07 and luckily i know Jake and Zach. Is it the same for the 07? Did Jake's buddy do the trans build for you?
Old Jul-20-11, 02:22 PM   #13
XplicitPerformance
XPTBSS
Real Name: Dru
Member # 2416
Like: 0
Originally Posted by 99kon View Post
Good deal Dru
I had Rusty build my own core. You may want to get with Jake and see if he will work with you on the tuning. He is not tuning as much as he used to due to a heavier work load with his Construction company.
XPTBSS v2 - SOLD!
Old Jul-20-11, 02:57 PM   #14
99kon
99kon's Avatar
Real Name: Ramon
Member # 12119
Like: 0
Yeah already talked to him and Zach so tuning and crossmember are good to go. I found a core now im just looking for somebody to rebuild it. Im getting prices now.
In your opinion is it worth doing if i will never be FI or N2?
I heard ill loose some low end out of the swap. Ill most likely at one point be cam and full bolt ons but that is probably it.
Old Jul-20-11, 03:42 PM   #15
XplicitPerformance
XPTBSS
Real Name: Dru
Member # 2416
Like: 0
are you breaking transmissions now? I have a cam/full exhaust and the low end loss is tolerable. I was holding back on upping the horsepower cause I didn't have a transmission to hold the power I already have. Now I may consider upping the horsepower with more mods now. I also went with a higher stall converter to make up for some of the low end loss.
XPTBSS v2 - SOLD!
Old Jul-20-11, 04:29 PM   #16
99kon
99kon's Avatar
Real Name: Ramon
Member # 12119
Like: 0
Not at all
Just bought the truck a month ago and the tranny feels good. Goes threw all the gears fine and shifts good. Truck only has a CAI but eventually will get all the bolt ons.
I was going to look into a stall hd2 kit and servos for the 70e so i figured might as well just do the swap, but im having second thoughts now. Why fix something that is not broken. I may still just get the crossmember and core just to have them. Then when the trans does take a shit, all i have to do is rebuild the 80e and go from there.
Old Jul-21-11, 10:22 AM   #17
XplicitPerformance
XPTBSS
Real Name: Dru
Member # 2416
Like: 0
Not at all
Yeah I would definitely consider the 80E if you plan on heavy mods. If you want to keep the 70E get you a good trans cooler, shift kit and KEEP TORQUE MANAGEMENT and you should be good.
The 80E takes a little but you get some too. You no longer need torque management so that helps. I was running 60% even on my built 70E. I may add a dual tranny cooler as this 3600 converter generates more heat than the old converter. In stop and go it can see 190 degrees. That is too hot for my taste.
XPTBSS v2 - SOLD!
Old Jul-21-11, 01:01 PM   #18
99kon
99kon's Avatar
Real Name: Ramon
Member # 12119
Like: 0
Yeah got a Trans cooler comingIll be getting everything i need except the trans so when i do need it all ill need is the trans rebuilt.
Thanks for the help
Old Jul-27-11, 06:18 AM   #19
jakebdb56
Real Name: Jake
Member # 12511
Casino cash: $51800
Like: 0
Ah cmon, what fun is torque management? lol. Honestly, a HD2 shift kit, servos, good converter (non-circle D restalled TB converter), and a solid trans tune will keep the 70E alive for quite some time. Nice thing is the 70E has a LOT of upgraded internals compared to even the 03-05 60E's.
Old Jul-28-11, 12:19 AM   #20
XplicitPerformance
XPTBSS
Real Name: Dru
Member # 2416
Like: 0
70E? I don't want to hear that word out your mouth sir!
XPTBSS v2 - SOLD!
