List of TSB's for 2006 6.0 TB pt 1 - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Modifications > TSB and Recall Sections
TSB and Recall Sections List any TSB or Recall for the 06-08 TBSS here
Old Jan-13-08, 05:48 PM   #1
camar0guy
Real Name: Daryl
Member # 833
Casino cash: $50140
Like: 0
Liked 0 Times in 0 Posts
Rep Power: camar0guy is an unknown quantity at this point
Exclamation List of TSB's for 2006 6.0 TB pt 1
06102A NOV 06 Recall - Aftermarket Leather Seat Cover Kits
05109 MAR 06 Recall - Tire/Loading Label Non-Compliance
05086A NOV 05 Recall - Power Steering Hose Fractures
TSB Number & Issue Date TSB Title
06045 JUN 06 Campaign - Missing Mercury Disposal Notice Label
06022 MAR 06 Campaign - Driver's Seat Module Programming
05-06-04-022D JUL 07 Fuel System - TOP TIER Gasoline Usage (Canada)
04-02-32-001C JUL 07 Steering Gear - Stub Shaft Bearing Kit Available
05-08-44-005A JUL 07 Entertainment System - Headphone Foam Pad Replacement
06-08-50-009B JUL 07 Restraints - Front Passenger Seat Accessory Precautions
05-08-46-009B JUN 07 OnStar(R) - Language Change Information
06-08-43-002B JUN 07 Wipers/Washers - Delayed Windshield Washer Fluid Spray
07-08-44-001A JUN 07 Audio System - Difficult To Install Fixed Antenna Mast
07-08-110-005 JUN 07 Interior - Headliner Sagging Near Dome Lamp
99-08-64-016B JUN 07 Body - Use of Silicone for Weatherstrip Maintenance
07-06-04-019 JUN 07 Engine Controls - MIL ON/Reduced Power/DTC P2138
00-06-01-026B JUN 07 Intake Manifold - Inspect/Replace After Engine Damage
06-08-44-012B JUN 07 Navigation System - DVD Navigation Update Program
04-05-25-002D JUN 07 Brakes - ABS Lamp ON/DTC's C0265/C0201/U1041
05-09-40-002B JUN 07 Restraints - Seat Belt Normal Locking Conditions
03-06-04-030E JUN 07 Fuel System - Driveability Issues/MIL ON/DTC's Set
06-08-43-003A JUN 07 Wipers - Performance/Cleaning Instructions/Maintenance
05-07-30-021A JUN 07 A/T - Can't Remove Key From Ignition Lock Cylinder
06-08-59-002B JUN 07 Body - Liftgate Glass Squeaks When Opening
02-06-03-008C MAY 07 Charging System - Lights Dim/Low Voltage Display
99-01-39-004B MAY 07 A/C - Odors In Hot/Humid Conditions
03-00-89-008C MAY 07 Body - Metal Panel Corrosion Protection
02-08-46-006B MAY 07 OnStar(R) - Incorrect GPS Location Reported During Call
01-07-30-042E MAY 07 A/T - 2-3 Upshift or 3-2 Downshift Clunk Noise
00-00-90-002G MAY 07 Tires - Proper Inflation Pressure Info.
00-05-22-002J MAY 07 Disc Brake System - Warranty Service and Procedures
06-00-89-029B MAY 07 Interior - Cleaning Seats, Carpet, Leather, Vinyl
07-08-49-006 MAY 07 Brakes - StabiliTrak(R) Light On/DTC C0244
07-07-30-010 MAY 07 A/T Controls - Snapshot Data Information
07-07-30-008 MAY 07 A/T - 4L60-E/4L65-E/4L70-E Production Update
03-08-111-002F APR 07 Body - Paint Chipping By Wheel Openings
05-08-51-008B APR 07 Body - Bumps or Rust Colored Spots in Paint
07-08-63-001 APR 07 Body - Polypropylene Energy Absorber Replacement
07-08-44-007 APR 07 Navigation System - Replacement Navigation Discs
07-03-10-008 APR 07 Tires - Slight/Mild Tire Feathering information
05-06-01-010A APR 07 Engine - Sealant Usage/procedures
06-01-39-002B APR 07 A/C - Front Blower Motor Inop/Won't Shut OFF
04-07-30-037C APR 07 A/T - DexronŽ-VI(R) Fluid Availability
01-06-01-011D APR 07 Engine - Oil Consumption Guideline Info.
07-08-98-001 APR 07 Body - Non-Approval of 'Clipping' for Collision Repair
02-08-42-004A MAR 07 Instruments - Reduced PRNDL Display Visibility
03-08-64-006C MAR 07 Body - Door(s) Are Difficult To Close
07-05-25-001 MAR 07 ABS/TCS - Service Lamp ON/DTC C0455 Set
07-06-01-004 MAR 07 Engine - Oil Leaks/Low Oil Lamp ON
06-03-09-006A MAR 07 Suspension - Rear of Vehicle Uneven/Sagging/Low
02-08-46-007B MAR 07 OnStar(R) - Loses GPS/Can't Renew Hands-Free Minutes
07-06-01-002 MAR 07 Engine - Revised Connecting Rod Bolt Torque
04-08-66-001D FEB 07 Body - License Plate Pocket Gasket Out of Position/Loose
06-08-45-006A FEB 07 Electrical - Trailer Wiring Harness Installation
06-07-30-007A FEB 07 A/T - MIL ON/DTC P0894/Harsh 1-2 Shift
05-07-129-001B FEB 07 A/T - Shift Lock Control Actuator Available
05-06-01-034E FEB 07 Engine - Oil Leak From Rear Cover Assembly Area
05-03-10-005B FEB 07 Wheels/Tires - 'Upsized' Wheel & Tire Information
04-07-30-013B FEB 07 Engine, A/T - Shift/Driveability Concerns/MIL ON
06-00-89-051A JAN 07 Locks - Key Code Securtiy Rules & Information
02-08-98-002B JAN 07 Body - Hem Flange Repair
05-07-30-018A JAN 07 A/T - Cold Weather Shift Characteristics
04-06-04-054A JAN 07 Engine Controls - Aftermarket Accessory Usage
00-03-10-006B JAN 07 Tires - Radial Force Variation (RFV) Information
99-09-40-005D DEC 06 Restraints - Availability of Seat Belt Extenders
03-07-30-007C DEC 06 A/T - Seemingly Slow 'Garage' Shifts
06-08-52-003A DEC 06 Body - L/H Front Door Won't Lock/Unlock With Key
02-07-30-001E DEC 06 A/T - Diagnostic Info on DTCs P0894/P1870
06-05-22-007 NOV 06 Brakes - Rotor/Drum Refinishing Labor Operations
06-00-89-054 NOV 06 Warranty - Claims Submission
04-06-01-029A NOV 06 Engine - Unnecessary Flushing Services
04-06-04-047G NOV 06 Fuel System - TOP TIER Detergent Gasoline
06-08-110-003A NOV 06 Interior - Headliner Sag at Rear of Sunroof
06-03-99-001 NOV 06 Suspension - Diagnosis/Repair of Rear Air Suspension
06-00-89-050 NOV 06 Warranty - DTC's Required On Repair Orders
03-08-48-006A NOV 06 A/C - Rear Window Defroster Tab Repair
06-08-66-011A NOV 06 Body - Liftgate Binding/Improper Fit/Rear Glass Broken
06-08-66-014 NOV 06 Body Controls - Liftgate Module Diagnostic Information
04-08-49-015A NOV 06 Instruments - Noises From The Instrument Cluster
05-01-38-012C NOV 06 A/C - Blower Motor Inop. or Works On Low Speed Only
01-07-31-002B NOV 06 M/T - Hydraulic Clutch Bleeding Procedure Improvement
01-08-42-001D OCT 06 Lighting - Replacement Guidelines for Lamp Condensation
06-02-32-013 OCT 06 Power Steering - Diagnostic Tips
05-06-02-012B OCT 06 Electrical - SES Lamp ON/DTC's P0480/P0526/P1481/P1484
05-08-46-001C OCT 06 OnStar(R) - System Inoperative/LED Not ON
06-04-20-003 OCT 06 Drivetrain - Revised Rear Axle Fluid Level/Checking
00-06-04-033B OCT 06 Emissions - OBDII I/M Readiness Testing
02-08-98-001C OCT 06 Body - Metal Panel Adhesive Bonding Information
00-00-89-027D OCT 06 Interior - Eliminating Unwanted Odors
04-03-10-001C OCT 06 Tires - Tread Puncture Repair Procedures
05-03-07-009A SEP 06 Wheel Alignment - Recommendations/Requirements
04-03-10-012A SEP 06 Wheels - Pitting/Brake Dust On Chrome Wheels
05-00-89-078A SEP 06 Fuel System - GM Fuel System Treatment Plus(R)
01-07-30-038D SEP 06 A/T - Poor Performance/MIL ON/DTC P0757
00-08-48-005B SEP 06 Body - Distortion On Outer Glass Surfaces
06-08-111-004 SEP 06 Body - Exterior Emblem Discoloration/Peeling/Blistering
Sponsored Links
Advertisement
Old Jan-13-08, 05:49 PM   #2
camar0guy
Real Name: Daryl
Member # 833
Casino cash: $50140
Like: 0
PT 2
06-03-10-010 SEP 06 Wheels - Changing Procedures/Precautions
05-06-02-002A AUG 06 Cooling System - DEXCOOL(R) Leak Detection Dye
03-07-29-004C AUG 06 M/T - Normal Operating Characteristics
06-03-08-011 AUG 06 Suspension - Revised Shock Module Replacement
06-09-41-003A AUG 06 Air Bag System - SIR Lamp ON/Multiple DTC's Set
03-03-10-007B AUG 06 Tires - Original Equipment Tire Characteristics
06-07-30-017A AUG 06 A/T - 4L60-E/4L65-E/4L70-E Whine/Whistle/Chirp Noise
00-06-02-006D AUG 06 Cooling System - Coolant Recycling Information
06-08-64-028 AUG 06 Body - Windows Stick/Bind/Slow/Noisy/Inoperative
06-06-04-037 AUG 06 Engine Controls - MIL Function During I/M Testing
00-03-10-002D AUG 06 Wheels Chrome Wheel Chemical Staining/Pitting/Corrosion
06-01-39-007 JUL 06 A/C - Contaminated R134A Refrigerant
06-07-30-016 JUL 06 A/T - 4L60-E, 4L65-E Fluid Leak From Bell Housing Area
06-06-04-035 JUL 06 Fuel System - E85 Fuel Usage Information
04-08-48-002C JUN 06 Body - Acoustic Windshield & Front Door Glass Available
99-08-51-007C JUN 06 Wheels - Aluminum Wheel Refinishing Recommendations
04-07-30-037B JUN 06 A/T - Dexron®(R) VI Fluid Availability
99-04-20-002D JUN 06 A/T - Clunk When Shifting From PARK/DRIVE/REVERSE
06-08-44-021 JUN 06 Audio System - Front Door Speaker Thump On Start Up
02-08-62-004B JUN 06 Body - Front Bumper Fascia Panel Wavy
03-07-30-043A MAY 06 A/T - Shift Lock Control Feature Function
06-04-21-001 MAY 06 Drivetrain - Updated Transfer Case Speed Sensor Conn.
04-06-03-005A MAY 06 Electrical - Proper Jump Starting Procedure
06-06-04-030 MAY 06 Fuel System - E85 Refueling Station Information
04-06-04-036B MAY 06 Engine Controls - Reprogramming Warranty Coverage
01-04-18-001E MAY 06 4WD/AWD Systems - Driveline Operating Characteristics
06-08-45-004 MAY 06 Electrical - Instrument Panel & General Wiring Repair
05-08-110-004A MAY 06 Interior - Cargo Cover Handle is Broken
06-08-44-015 APR 06 Audio System - Portable Audio Equipment Noise
06-06-01-010 APR 06 Exhaust System - Close-Coupled Cat Converter Information
05-03-10-003B APR 06 Wheels/Tires - Slow Leaks From Aluminum Wheels
05-08-128-001A APR 06 Instruments - DIC Vehicle Customization Change
05-08-111-006B APR 06 Lighting - Center Mounted Stop Lamp Applique loose
05-08-64-002B APR 06 Body - Door Latches Freezes in Extreme Cold
02-08-48-001B MAR 06 Body - Urethane Adhesives for Glass Applications
06-08-42-005 MAR 06 Lighting - Fog Lamp Beam Shakes While Driving
05-01-39-002A MAR 06 A/C - Musty Odors On Start Up
05-08-44-016A MAR 06 Audio System - Poor Radio Reception/Station Drifting
05-06-03-002B MAR 06 Battery, Charging System - Electrical Diagnostics
02-06-03-009B MAR 06 Electrical - Battery Charging Tips
02-06-04-015A MAR 06 Starting System - Engine No Start/No Crank Condition
05-04-21-003A MAR 06 4WD/AWD System - 'Service 4WD' Lamp ON/DTC C0374
05-08-46-008A MAR 06 OnStar(R) - Language Change (Canada Only)
02-08-46-010G MAR 06 OnStar(R) - Programming for Canadian French
06-03-10-004 MAR 06 Tires/Wheels - Wheel Weight Usage Precautions
05-08-46-004A FEB 06 OnStar(R) - Incorrect Phone Number Assigned to Vehicle
01-07-30-036F FEB 06 A/T - 4L60-E, 4L65-E, 4L70-E DTC P0756 Diagnostics
02-06-05-004B FEB 06 Accessories - DTC's P0300, P1380, P1381
06-08-66-001 FEB 06 Body - Revised Liftgate Lock Cylinder Replacement
06-06-02-003 FEB 06 Cooling System - Electro-Viscous Fan Clutch Operation
05-08-44-029A FEB 06 Audio System - Radio Knob Availability
04-08-46-002B FEB 06 OnStar(R) - Unable to Connect, Bulletin Cancellation
02-07-30-052D FEB 06 A/T - Fluid Cooler Flushing
06-06-04-007 FEB 06 Electrical - DTC P0606/P0689/P1516/P1682/P2176
06-06-04-006 JAN 06 Fuel System - Fuel Filler Neck Flapper Door Elimination
01-08-66-007B JAN 06 Lighting - Center Mounted Stop Lamp Applique Loose
00-06-01-012B JAN 06 Engine - Surface Conditioning Disc Usage Prohibition
05-08-111-009B JAN 06 Body - Body Side Moldings Come loose
99-08-52-005B JAN 06 Keyless Entry - Operational Characteristics
06-08-44-002 JAN 06 Entertainment System - Rear Video Display Replacement
04-06-04-051B JAN 06 Fuel System - Fuel Injector Maintenance Cleaning
05-09-41-010 DEC 05 SRS - New SIR System Disabling Procedure
05-03-10-020 DEC 05 Tires/Wheels - Nitrogen Gas Usage for Filling Tires
05-03-99-002 DEC 05 Suspension - Air Suspension Leak Diagnosis Addition
02-08-44-007B DEC 05 Audio System - Vinyl Roofs Affect Radio Performance
03-09-40-006B DEC 05 Restraints - Seat Belt Retractor Jamming Prevention
99-08-51-001A NOV 05 Body - Paint-Less Dent Repair Recommendations
02-01-39-004B NOV 05 A/C - New PAG Oil
05-03-10-016 NOV 05 Wheels/Tires - 18 Inch Wheel/Tire Availability
05-00-89-072 OCT 05 Engine/Fuel System - Oil/Fuel Additive Recommendations
04-08-43-005C OCT 05 Wipers/Washers - Serviceable Wiper Motor Components
01-07-30-030B OCT 05 A/T - 4L60-E/4L65-E Harsh 1-2 Upshift Diagnosis
05-07-30-026 OCT 05 A/T - 4L70-E Identification/Components
01-07-30-041B OCT 05 A/T - Diagnosing Fluid Leaks
01-07-30-010B OCT 05 A/T - Torque Converter Replacement
01-07-30-002E SEP 05 Electrical - A/T Stuck in 2nd/3rd Gear/MIL ON/DTC's
05-06-04-060 SEP 05 Engine, A/T Controls - Shared Diagnostic Trouble Codes
05-08-44-027 SEP 05 Audio System - XM Radio DTC B1259
02-07-30-024B AUG 05 A/T - Cracked Case Diagnosis
03-06-04-012A AUG 05 Electrical - Harness Connection Inspection
04-08-48-001B JUN 05 A/C - Broken Rear Window Defogger Grid Detection
89358 NOV 88 Battery - Diagnosis and Charging
Old Jan-14-08, 03:27 PM   #3
Blazen
Blazen's Avatar
Real Name: Seth
Member # 16
Casino cash: $112937
Like: 0
Liked 1 Time in 1 Post
Rep Power: Blazen is an unknown quantity at this point
TXBlazenSS
Thanks!!
07 Black - Few mods
Old Jan-14-08, 03:36 PM   #4
idreama300
Real Name: Nate
Member # 472
Casino cash: $49650
Like: 0
Rep Power: idreama300 is an unknown quantity at this point
Thanks man, thats great.
Old Jan-14-08, 03:39 PM   #5
Last Canadian Exit
Last Canadian Exit's Avatar
Real Name: Mike
Member # 794
Casino cash: $50100
Like: 0
Rep Power: Last Canadian Exit is an unknown quantity at this point
I don't know if I want to read all these!
Great Googly Moogly....
Old Jan-15-08, 01:32 AM   #6
06pearl
06pearl's Avatar
Real Name: Rob
Member # 358
Casino cash: $65550
Like: 0
Rep Power: 06pearl is an unknown quantity at this point
retarded question.. so what does this mean? if some of that shit is wrong with mine, take it to the dealership??
06 awd - summit white/black stockers
Old Jan-20-08, 09:03 AM   #7
matts
Member # 27
Casino cash: $54000
Like: 0
Rep Power: matts is an unknown quantity at this point
wouldn't you do that anyway if it's under warranty?
the way i understand a TSB is GM isn't admitting they have a problem (like a recall). but if someone comes in complaining of a certain issue the TSB is supposed to give the tech a push in the right direction of getting it fixed...right.
when you walk into a dealership and hand them the TSB# and tell them what's up they're more likely (in my experiences) to take you serious and fix the problem with little, or no, questions asked.
Old Jan-24-08, 09:46 PM   #8
thechad
thechad's Avatar
Real Name: Chad
Member # 1181
Casino cash: $50400
Like: 0
Rep Power: thechad is an unknown quantity at this point
True That
2007 Silverstone AWD SS3 - Vector 93 Tune, HSRK and Parts of their Intake - KB's SLIZZAAMMED F/31.875 R/32.125
Drivetrain and Suspension mods soon
Old Feb-26-08, 09:24 AM   #9
ssvegas
low and slow
ssvegas's Avatar
Real Name: Nick
Member # 2037
Casino cash: $282300
Like: 1
Liked 117 Times in 95 Posts
Rep Power: ssvegas is a jewel in the roughssvegas is a jewel in the roughssvegas is a jewel in the rough
what do you think they would do about both of these?
Originally Posted by JD_SS View Post
Way to throw up all over the OP's build thread you fucking dick faces.
Old Feb-26-08, 09:29 AM   #10
ssvegas
low and slow
ssvegas's Avatar
Real Name: Nick
Member # 2037
Like: 1
what the hell is this???
Old May-06-08, 07:45 PM   #11
sleeper22
Real Name: Thomas
Member # 32
Casino cash: $420850
Like: 104
Liked 33 Times in 20 Posts
Rep Power: sleeper22 is a name known to allsleeper22 is a name known to allsleeper22 is a name known to allsleeper22 is a name known to allsleeper22 is a name known to allsleeper22 is a name known to all
How do we know exactly what these TSB's mean?
24's, Belltech lowering struts, DJM custom reworked upper control arms and strut arm, SS springs, DJM shocks with adjusted airbags, adjustable upper & lower control arms, adjustable panhard bar, shorter front & rear endlinks. Frame and body mods...
Old May-15-08, 10:58 PM   #12
hotrodder4life
Real Name: Doug
Member # 2528
Casino cash: $52950
Like: 0
Rep Power: hotrodder4life is an unknown quantity at this point
Does anyone know were we can actually read the TSB's without needing to join sometype of site or anything??
Old Aug-08-08, 11:27 PM   #13
threepointsix
threepointsix's Avatar
Real Name: Kyle
Member # 815
Casino cash: $50400
Like: 0
Rep Power: threepointsix is an unknown quantity at this point
What does this have to do w/ a TBSS???
Or this WTF?????
06 Silverstone 2WD SS: Vector flash, cai, de-badged hatch, rr bags lowered/leveled, 4500lbs!//// '05 Mitsu Evo RS: Works TR340(flash, cams, bored throttle body, turbo-tip quiet stealth exhaust w/race cat), 275/35/18 on 18/9.5's, race swaybar, springs,3150 lbs AWD
Old Oct-09-08, 04:34 PM   #14
Dixie
Real Name: Jason
Member # 2777
Casino cash: $58500
Like: 0
Rep Power: Dixie is an unknown quantity at this point
Do these only apply to still in warranty TBSS's?
Nick's Custom Detailing 214-205-1287
Resident jack of all trades, but certified smartass.
2006 Black TBSS- DJM kit, lowered rear bags, Panhard bar, foglight and low beam HID's, 2% window tint all around and 35% on windshield, TR6's, R1 Concepts rotors and pad all around, Muffler delete, level holy crap that's badass from Pheonix trans, Pheonix trans 3000 stall, DIY tranny cooler, more to come.
Old Jan-05-09, 05:01 PM   #15
Saladbar
Saladbar's Avatar
Real Name: Shawn
Member # 157
Casino cash: $141000
Like: 0
Rep Power: Saladbar is an unknown quantity at this point
What's this one??
Mine does this. Built tranny though, so they may not touch it.
12.25@110.4mph - 4650# race weight ... 224/230 112+4, Kooks LTs, 3600 Vig. TC, ADM MAF, fender mount CAI, (now with TSP Stg 2.5 243's).
Fastest "cam only" TBSS
No N2O fed times worth mentioning yet.
Old Jan-15-09, 05:42 PM   #16
mooley09
Real Name: John
Member # 4525
Casino cash: $50000
Like: 0
Rep Power: mooley09 is an unknown quantity at this point
Good stuff... Basically if your car hasn't had the warranty void or it won't if you take it in. Get all the TSB's that your experiencing and tell them. They will fix it. If its a weird one, they will elaborate on it for you and explain it if they can. If they can't they should point you in the direction of someone who can!
Old Jan-25-09, 08:35 PM   #17
C6U6I6H
C6U6I6H's Avatar
Real Name: Corey
Member # 4276
Casino cash: $168100
Like: 3
Rep Power: C6U6I6H will become famous soon enough
Where can i get more information on these??? Had these problems for a while and my dealer is trying to dick me and saying they can't replicate the problem or hear what i'm hearing...
'06 AWD 3SS, TSP Forged 404, FLT Lvl 7, L92 Heads, And some bolt ons. 412AWHP/418AWTQ
Old Jan-26-09, 06:29 AM   #18
Dixie
Real Name: Jason
Member # 2777
Casino cash: $58500
Like: 0
Mine does all of these. too bad my warranty went out a long time ago. boo.
Old Jan-26-09, 06:37 AM   #19
C6U6I6H
C6U6I6H's Avatar
Real Name: Corey
Member # 4276
Like: 3
my warranty's out too but i've got documented listings of me telling the dealer of the problem and them not fixing them...
Old Feb-05-09, 10:37 PM   #20
LilD3v1lRydr
LilD3v1lRydr's Avatar
Real Name: Jason
Member # 3320
Casino cash: $807200
Like: 539
Liked 180 Times in 77 Posts
Rep Power: LilD3v1lRydr has much to be proud ofLilD3v1lRydr has much to be proud ofLilD3v1lRydr has much to be proud ofLilD3v1lRydr has much to be proud ofLilD3v1lRydr has much to be proud ofLilD3v1lRydr has much to be proud ofLilD3v1lRydr has much to be proud ofLilD3v1lRydr has much to be proud ofLilD3v1lRydr has much to be proud of
all my doors, cept the drivers one is hard to close. and ive been hear the clunk noise when going from park to reverse, or neutral to drive...
should i be concerned? or take it to the dealer? im still under warranty.
