new hid fog light help - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > Electrical/Stereo/Lighting > Lighting
Old Sep-12-10, 12:15 PM   #1
cyacop
cyacop's Avatar
Real Name: drew
Member # 5077
Casino cash: $193796
Like: 0
Liked 2 Times in 2 Posts
Rep Power: cyacop will become famous soon enoughcyacop will become famous soon enough
Default new hid fog light help
i am about to lose my mind !!! i just installed a set of hid foglights and the driver side is flickering and driving me nuts !!! i unplugged and plugged everything back in and still flicking. i need some pro fessional help. if it isnt going to be able to be stopped i just wont turn them on. it makes it look like the bulb is loose
Sponsored Links
Advertisement
Old Sep-12-10, 12:17 PM   #2
rjackso3
rjackso3's Avatar
Real Name: Ryan
Member # 4249
Casino cash: $319775
Like: 0
Liked 0 Times in 0 Posts
Rep Power: rjackso3 is on a distinguished road
A JACKS on 54
Loose bumper cover?
Old Sep-12-10, 12:19 PM   #3
SSDUFF
SSDUFF's Avatar
Real Name: Moe
Member # 8352
Casino cash: $208500
Like: 0
Rep Power: SSDUFF is an unknown quantity at this point
fuse about to go bye-bye?
Old Sep-12-10, 12:28 PM   #4
cyacop
cyacop's Avatar
Real Name: drew
Member # 5077
Like: 0
a fuse about to go out would cause one to flicker ? and no , its not a loose bumper . i havent even driven it yet. plus i have the lower bumper stabilizers from gm
Old Sep-12-10, 02:25 PM   #5
SSDUFF
SSDUFF's Avatar
Real Name: Moe
Member # 8352
Like: 0
My driver's side was flickering after I installed them after a couple of trips they both stopped working..Pulled all the wiring to check for errors nothing pulled the fuse looked fine replaced it anyways and both worked. idk luck?
Old Sep-12-10, 02:36 PM   #6
cyacop
cyacop's Avatar
Real Name: drew
Member # 5077
Like: 0
is it fuse number 11 ?
Old Sep-12-10, 02:49 PM   #7
dfwwiz
The Wiz
dfwwiz's Avatar
Real Name: Kevin
Member # 3413
Casino cash: $1169897
Like: 568
Liked 326 Times in 218 Posts
Rep Power: dfwwiz Gives oral for rep pointsdfwwiz Gives oral for rep pointsdfwwiz Gives oral for rep pointsdfwwiz Gives oral for rep pointsdfwwiz Gives oral for rep pointsdfwwiz Gives oral for rep pointsdfwwiz Gives oral for rep pointsdfwwiz Gives oral for rep pointsdfwwiz Gives oral for rep pointsdfwwiz Gives oral for rep pointsdfwwiz Gives oral for rep points
My driver side low beam does that all the time. I think its the ballast with a defect since I switched bulbs around its still the same side (ballast).
WEBSITE:http://dfwizleds.wix.com/leds Site is under construction-getting revamped.
Old Sep-12-10, 03:25 PM   #8
SSDUFF
SSDUFF's Avatar
Real Name: Moe
Member # 8352
Like: 0
Yes sir underhood #11 should be a 15 if I'm not mistaken.
Old Sep-17-10, 08:26 PM   #9
steveo346
Fbody Guru
Real Name: Steven
Member # 9049
Casino cash: $55300
Like: 0
Rep Power: steveo346 is an unknown quantity at this point
What size bulb is the fog light?
Old Sep-17-10, 09:55 PM   #10
cyacop
cyacop's Avatar
Real Name: drew
Member # 5077
Like: 0
i believe they are 880 ? does that sound right ? i cannot drive and leave them on . the flicker off the drivers side fog drives me insane. if i am behind someone i completly focus on it and i feel that everyone coming toward me in oncoming traffic is looking at it and saying WTF ? lol i might add that at first it doesnt do it but it gets progressively worse as time goes
Old Sep-18-10, 10:20 AM   #11
summerwolf
summerwolf's Avatar
Real Name: Caleb
Member # 7796
Casino cash: $184282
Like: 0
Rep Power: summerwolf is on a distinguished road
ballast needs to be replaced....but check the wiring and fuse first.
Old Sep-18-10, 05:41 PM   #12
cyacop
cyacop's Avatar
Real Name: drew
Member # 5077
Like: 0
if it is a faulty ballast that is going to suck ! they are brand new
Old Sep-28-10, 08:40 PM   #13
steveo346
Fbody Guru
Real Name: Steven
Member # 9049
Casino cash: $55300
Like: 0
thanks, ill order the 880 hid kit for the fogs, am i correct in saying that the headlight bulbs are 9006's?
Old Sep-28-10, 10:25 PM   #14
Papabear
stupid white guy
Papabear's Avatar
Real Name: Buddy
Member # 9219
Casino cash: $483210
Like: 39
Liked 120 Times in 84 Posts
Rep Power: Papabear has a brilliant futurePapabear has a brilliant futurePapabear has a brilliant futurePapabear has a brilliant futurePapabear has a brilliant futurePapabear has a brilliant futurePapabear has a brilliant futurePapabear has a brilliant futurePapabear has a brilliant futurePapabear has a brilliant futurePapabear has a brilliant future
Yeah, 9006.
And a fuse is never "about to go out." A fuse is a current limiter basically. A 10 amp fuse can allow 10 amps of current to flow through it. It is designed so that if more than 10 amps go through the fuse, the filament/blade whatever breaks (loses continuity) and the circuit is broken, cutting power.
I guarantee you it's not a fuse. Yes, it was luck when you replaced the fuse.
Old Sep-30-10, 10:57 AM   #15
hpjunke
AKA Sonny
hpjunke's Avatar
Real Name: Ryan
Member # 5634
Casino cash: $149125
Like: 0
Liked 1 Time in 1 Post
Rep Power: hpjunke is on a distinguished road
if its only one that is flickering why dont you try and sawp ballast with your known good one and see what happens . If it still flickers then id say a ground issue or wiring of that sort.... good luck .
Old Sep-30-10, 10:31 PM   #16
GRCYGTR
GRCYGTR's Avatar
Real Name: Colby
Member # 9347
Casino cash: $74900
Like: 0
Rep Power: GRCYGTR is an unknown quantity at this point
THIS...swap ballasts or swap bulbs, whatever is easier... i had to do this because my low beams did not match color wise and it ended up being the bulbs but i checked both ways...also, make sure your fog light just isn't mounted loose...i know they are spring loaded or whatever but its worth a shot
2006 Trailblazer SS 2WD
Kenwood Nav/DVD, 5000k HIDs, 6 Beam mod
Old Oct-01-10, 02:18 AM   #17
SSCTBSS
J&S AUDIO
SSCTBSS's Avatar
Member # 6028
Casino cash: $105600
Like: 0
Liked 3 Times in 2 Posts
Rep Power: SSCTBSS is an unknown quantity at this point
i would add in a relay harness if u dont all ready have one. and yeah its prob a bad ballast. when u dont use a relay harness ballats go much faster which in turn fucks the bulb up over time. good luck.
2013 Camaro SS sold the 2006 Trailblazer SS
Old Oct-01-10, 10:33 PM   #18
cyacop
cyacop's Avatar
Real Name: drew
Member # 5077
Like: 0
i will try out putting the ballast on the other side. cant believe i didnt think of that . now i officially feel retarded. lol
Old Oct-01-10, 11:45 PM   #19
Evil SS 2006
Big Gulps, Huh? Whelp...
Evil SS 2006's Avatar
Real Name: Steven
Member # 20
Casino cash: $1181585
Like: 2
Liked 32 Times in 17 Posts
Rep Power: Evil SS 2006 has a brilliant futureEvil SS 2006 has a brilliant futureEvil SS 2006 has a brilliant futureEvil SS 2006 has a brilliant futureEvil SS 2006 has a brilliant futureEvil SS 2006 has a brilliant futureEvil SS 2006 has a brilliant futureEvil SS 2006 has a brilliant futureEvil SS 2006 has a brilliant futureEvil SS 2006 has a brilliant futureEvil SS 2006 has a brilliant future
You guys are barking up the wrong tree, the 880 bulbs are such a tight fit that when you installed them you likely broke the ceramic sleeve on the cathode which is causing the circuit to clip...that is what your flicker is! When installing most bulbs into our fogs, you need to loosen the mounting base screws in the housing and install the bulb, them tighten the screw down...
2015 Yeti SB6c XTR Di2 / 2015 Cannondale Jekyll Carbon Team / 2015 Pinarello FCX Hyrdo Ultegra Di2 Hyd Disc
Old Oct-01-10, 11:54 PM   #20
Papabear
stupid white guy
Papabear's Avatar
Real Name: Buddy
Member # 9219
Like: 39
For what it's worth, I cracked my little ceramic piece on one and 3000 miles later, not one flicker
