Stabilitrak Question - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Modifications > General TBSS Questions
General TBSS Questions General TBSS Related Questions. Ask it here!
Old Aug-25-10, 02:50 PM   #1
bsstb
bsstb's Avatar
Real Name: Barrett
Member # 3278
Casino cash: $300215
Like: 0
Liked 0 Times in 0 Posts
Rep Power: bsstb will become famous soon enough
Default Stabilitrak Question
I hopped in the SS this morning after getting a drink for work. Pulling out on the street I noticed the "Service Stabilitrak" on the DIC, of course I had the OH $hit look on my face when I saw it, I just pulled over, Shut the SS down waited for a sec then started it back up to no message.
So here is my question. What is the usual cause for the "service stbilitrak" message to come up?
07 Black 1SS gone but definitely not forgotten.
09 White Hot Pontiac G8 GT
Sponsored Links
Advertisement
Old Aug-25-10, 02:55 PM   #2
TWO-TONS-OF-FUN
Moderator
TWO-TONS-OF-FUN's Avatar
Real Name: Greg
Member # 1248
Casino cash: $1997662
Like: 18
Liked 164 Times in 49 Posts
Rep Power: TWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep pointsTWO-TONS-OF-FUN Gives oral for rep points
it needs servicing.
Old Aug-25-10, 02:59 PM   #3
Kdubs
Kdubs's Avatar
Real Name: Katie
Member # 3990
Casino cash: $680399
Like: 0
Liked 3 Times in 3 Posts
Rep Power: Kdubs is just really niceKdubs is just really niceKdubs is just really niceKdubs is just really nice
What were the conditions it happened? speed you were going? how much of a turn? any loose gravel etc..
btw, off topic you need to update your sig pic hehe "http://www.tbssowners.com/forums/image.php?u=3390&type=sigpic&dateline=1281849635"
Old Aug-25-10, 03:03 PM   #4
bsstb
bsstb's Avatar
Real Name: Barrett
Member # 3278
Like: 0
Well I Know speed and road conditions should be considered. But honestly I wasn't paying much attention. But it was dry pavement no loose stuff. now throttle position now clue.
and Katie I will have to change my Sig when I get home.
Old Aug-25-10, 03:41 PM   #5
TWO-TONS-OF-FUN
Moderator
Real Name: Greg
Member # 1248
Like: 18
barret, please read this...
#PIT4576F: Service Stabilitrak Indicator Illuminated DTC C0131 - keywords booster brake drag lamp light pedal shake stability vib vibration VSES wear - (Jul 17, 2009)
Subject: Service Stabilitrak Indicator Illuminated DTC C0131
Models: 2007 Buick Rainier
2007-2008 Chevrolet Trailblazer models
2007-2008 GMC Envoy models
2007-2008 Saab 97x
This PI was superseded to include additional TAC Admin Details. Please discard PIT4576E.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A customer complaint of a Service Stability Indicator illuminated at times and the EBCM DTC C0131 stored. The DTC may set a plausibility correlation fault if the Master Cylinder Pressure sensor senses hydraulic brake pressure with no brake switch input to the EBCM. The driving conditions to induce this DTC are "Parade" type driving or as if the customer is at a "Drive Thru" window. These are typically light brake applications with slow vehicle movements.
Recommendation/Instructions:
Using the Tech II, navigate to the EBCM's Data Display. Identify the parameter that displays Master Cylinder Pressure readings in Voltage and PSI. Does the Master Cylinder Pressure reading dynamically change output based on applying and releasing the brake pedal? If yes, proceed to step 2 for vehicles equipped with Electric Adjustable Pedals - RP0 JF4 or Step 3 for vehicles not equipped with this feature. Otherwise, replace BPMV.
Physically inspect for any slack/free-play movement on the mounting of pedal adjusting motor assembly to the brake pedal arm hardware. There are two staked pins for mounting and securing the gear box of motor, if one or both pin(s) have not adequately staked, it will cause the slack/free-play, thus causes inadvertent switch interruption (circuit may close even with foot is still on the brake pedal). If there is a slack/free-play exist, replace brake pedal assembly and retest it with drive the vehicle on a few parade laps (with light brake apply) around the dealership lot verifying DTC C0131 does not return. If no slack/free-play, proceed to step 3.
Replace the brake booster with current SPO parts. After booster installation is complete, drive the vehicle on a few parade laps (with light brake apply) around the dealership lot verifying DTC C0131 does not return.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Old Aug-25-10, 03:42 PM   #6
TWO-TONS-OF-FUN
Moderator
Real Name: Greg
Member # 1248
Like: 18
#08-05-25-005: Intermittent StabiliTrak Indicator Light Blinking, StabiliTrak Active Message Displayed, DTC C0196 Set (Reprogram Electronic Brake Control Module (EBCM)) - (Oct 1, 2008)
Subject: Intermittent StabiliTrak® Indicator Light Blinking, StabiliTrak® Active Message Displayed, DTC C0196 Set (Reprogram Electronic Brake Control Module (EBCM))
Models: 2006-2007 Buick Rainier
2006-2009 Chevrolet TrailBlazer Models
2006-2009 GMC Envoy Models
2006-2009 Saab 9-7X
2006-2009 Isuzu Ascender Models
This bulletin provides information on two different conditions.
Condition #1
Some customers may comment on a Service StabiliTrak® indicator light along with a Service StabiliTrak® message displayed in the DIC. Upon investigation, the technician may find DTC C0196 set in history.
Condition #2
Some customers may comment on a blinking StabiliTrak® indicator light along with a StabiliTrak Active message displayed in the DIC during normal driving conditions. No DTCs will be found with this concern.
Cause
This condition may be caused by a software anomaly within the electronic brake control module (EBCM) that allowed the yaw offset to be falsely learned.
Correction
Do This
Don't Do This
Reprogram the EBCM.
Do not replace the yaw sensor or EBCM for this condition.
Important: From the controller list, select "VSES Vehicle Stability Enhancement System Control Module."
If routine diagnosis using SI does not reveal any obvious cause, reprogram the EBCM using SPS with the latest software available on TIS2WEB. Refer to the Service Programming System (SPS) procedures in SI. As always, make sure your Tech 2® is updated with the latest software version.
Warranty Information (excluding Saab U.S. Models)
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
H2508
Electronic Brake and/or Traction Control Module Reprogramming with SPS
Use Published Labor Operation Time
Warranty Information (Saab U.S. Models)
Labor Operation
Description
Failed Object
Fault/Reason Code
Location Code
Warranty Type
Repair/Action Code
Labor Time
1002003
52160
79
0
01
05
Old Aug-25-10, 03:43 PM   #7
TWO-TONS-OF-FUN
Moderator
Real Name: Greg
Member # 1248
Like: 18
#PIT4688: Service Stability And Red Brake Light Warning Indicators On With No DTCs - keywords brake cluster code codes display fluid indicator IPC lamp level light low no none panel red service stability - (Aug 1, 2008)
Subject: Service Stability and Red Brake Light Warning Indicators on with No DTC's
2006-2009 Chevrolet Trailblazer models
2006-2009 GMC Envoy models
2006-2009 Saab 97x
Condition/Concern:
Some customers may comment that the Service Stability and Red Brake warning lamps are illuminated. A Technician may scan the EBCM for DTC's and find none stored. These indicators with no DTC's stored, may be the result of low fluid in the brake master cylinder reservoir.
Using the Tech 2, build as... Chassis > EBCM > Data Display > VSES. The tech 2 will display OK or Low for this parameter. Monitor the Diff.Pressure/Fluid Level parameter. If the value is low, follow SI Document ID 1923428.
© 2010 General Motors. All rights reserved.
Old Aug-25-10, 03:45 PM   #8
TWO-TONS-OF-FUN
Moderator
Real Name: Greg
Member # 1248
Like: 18
can through those 3 informational posts and see if one pertains to your issue...
Old Aug-25-10, 04:02 PM   #9
bsstb
bsstb's Avatar
Real Name: Barrett
Member # 3278
Like: 0
Greg it sounds alot like the Second one but. let me see if I can go to Vatozone to see if i can pull the code on my way home tonight.
But as far as I know this the only time this has happened.
Old Aug-25-10, 04:03 PM   #10
TWO-TONS-OF-FUN
Moderator
Real Name: Greg
Member # 1248
Like: 18
let them read the code... DO NOT CLEAR THE CODE.
that way if they cant read it.. your dealer can.
