Truck will not start , starter just clicks when key is turned - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Modifications > General TBSS Questions
General TBSS Questions General TBSS Related Questions. Ask it here!
Old Aug-01-10, 04:13 PM   #1
TrueLS2
Real Name: SHawn
Member # 1038
Casino cash: $196150
Like: 0
Liked 0 Times in 0 Posts
Rep Power: TrueLS2 is an unknown quantity at this point
Default Truck will not start , starter just clicks when key is turned
So my truck will not start , all I get is a click noise coming from the starter when key is turned.. I'm not sure if it's doing this when the starter gets hot or is it somthing to do with the ignition switch? it just started doing this today any ideas? I'm currently stuck at the track with a none starting truck help!!!
06 Awd Cam+bolt ons Slowhawk Performance tuned.
12.49 @ 107mph with 1.76 60'
Sponsored Links
Advertisement
Old Aug-01-10, 04:17 PM   #2
awdls2
NLMotorsports
awdls2's Avatar
Real Name: Justin
Member # 4841
Casino cash: $178780
Like: 0
Rep Power: awdls2 is on a distinguished road
U sure the battery isn't dying?
08 tbss hids, ieatsrt8 intake, circle d, fast motorsports tune, addco sways,efans, 160tstat OBX longtubes KBEE's Originally Posted by MommyMobileSS-- pretty soon your engine is gunna unbolt itself and run the fuck away cause it hates you
Old Aug-01-10, 04:19 PM   #3
ssprince
The Lurker
ssprince's Avatar
Real Name: Anthony
Member # 1369
Casino cash: $1327200
Like: 3
Liked 114 Times in 74 Posts
Rep Power: ssprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant futuressprince has a brilliant future
These trucks are notorious for ignition switches!! If it's a bad starter though, you can turn and hold the key in the "start" position, while someone gives the starter a "whack" with a blunt object! It may start, if it does start, you will know that the starter is kapoot! Hope this helps!!!
Brand new RPM Trans....Broke with under 8K miles...No warranty or help.
Old Aug-01-10, 04:26 PM   #4
TrueLS2
Real Name: SHawn
Member # 1038
Like: 0
Nope it's not a dead battery the starter sounds like it wants to go but all it does is click. it almost sounds like what my old s10 did when the starter is over heated. what does a starter go for?
Old Aug-01-10, 04:52 PM   #5
KhellendrosXS
KhellendrosXS's Avatar
Member # 7000
Casino cash: $74860
Like: 0
Rep Power: KhellendrosXS is an unknown quantity at this point
If the solenoid on the starter is just clicking Id first make sure the connection from the battery to the starter is good, tight and clean. Starters draw a lot of amps and if the power isnt there it aint turning over.
If thats not it Id be looking into a new starter.
Old Aug-01-10, 08:44 PM   #6
TrueLS2
Real Name: SHawn
Member # 1038
Like: 0
Well after alot of turning the key and clicking the truck finally started and got me home. Ill have to jack it up tommorow and check out the situation and report back. Thanks
Old Aug-01-10, 08:48 PM   #7
ssprince
The Lurker
ssprince's Avatar
Real Name: Anthony
Member # 1369
Like: 3
Did you try to "whack" it?
Old Aug-01-10, 09:21 PM   #8
907TBSS
907TBSS's Avatar
Real Name: Brett
Member # 2265
Casino cash: $536536
Like: 294
Liked 175 Times in 115 Posts
Rep Power: 907TBSS is a name known to all907TBSS is a name known to all907TBSS is a name known to all907TBSS is a name known to all907TBSS is a name known to all907TBSS is a name known to all
ovRRev
Do we have Crank Pos. sensors?
Old 02 Dodge did the same damn thing... I'd go about every 10 months and have another replaced. Just had to cycle the key multiple times.
But this is prob. another ignition switch issue I suppose.
-08 3SS Black Granite 365" Forged H/C LeftCoast32/LEP/AFR/Phoenix Trans Semper Fi
Old Aug-02-10, 03:40 AM   #9
TrueLS2
Real Name: SHawn
Member # 1038
Like: 0
nah I didn't even try to hit it.. Went out this morning and it started fine.. Not sure what it could be right now. Is this even a symptom of an ignition switch shitting the bed or is it deffinatly a starter going?
Old Aug-02-10, 05:39 AM   #10
Lsgun1
Member # 8900
Casino cash: $110099
Like: 0
Rep Power: Lsgun1 is an unknown quantity at this point
Sounds like a starter to me
Old Aug-02-10, 08:30 AM   #11
BRob06SS
Real Name: Brett
Member # 5095
Casino cash: $191620
Like: 0
Rep Power: BRob06SS is on a distinguished road
BRob-
Ignition switch
06 TBSS LT - 2wd, Forged 402, Eagle internals, L92 WCCH, PCM4Less custom cam and 4" FWI, Kooks 1 7/8, FLT Stg 5, Yank 3600 SOLD
Old Aug-02-10, 08:46 AM   #12
TrueLS2
Real Name: SHawn
Member # 1038
Like: 0
Trying to figure out how I can actually check this without shot gunning parts at the truck
Old Aug-02-10, 05:20 PM   #13
Lsgun1
Member # 8900
Like: 0
The problem is that it intermittently does not start. If it was a frequent no start you could try to jump the starter by putting 12v directly to it.
Old Aug-02-10, 06:00 PM   #14
TrueLS2
Real Name: SHawn
Member # 1038
Like: 0
Ok well its started all day today without a problem.. Should i just go ahead and have the starter replaced for a piece of mind? I jacked up the truck and looked under there im AWD with headers looks like a bitch and a half job!
Old Aug-02-10, 06:37 PM   #15
jetttstream
HIDs, LEDs, CAIs!
jetttstream's Avatar
Real Name: Mike
Member # 2086
Casino cash: $875180
Like: 0
Liked 4 Times in 4 Posts
Rep Power: jetttstream has a spectacular aura aboutjetttstream has a spectacular aura about
I still think it sounds like ignition switch...
TBSS - Enthusiast and Vendor, HID LED guru.
HID and DRL stuff still available.
Old Aug-02-10, 07:16 PM   #16
TrueLS2
Real Name: SHawn
Member # 1038
Like: 0
Gonna do an ignition switch first and if it happens again after that starter it is!
Old Aug-03-10, 09:28 AM   #17
Lsgun1
Member # 8900
Like: 0
Good luck.
On a side note where in MA are you?
Old Aug-03-10, 03:57 PM   #18
TrueLS2
Real Name: SHawn
Member # 1038
Like: 0
Well put in a new ignition switch pretty damn easy to do! Only time will tell if i get stuck somewhere im hoping it fixed the problem. Thanks for the info.
Old Aug-03-10, 05:32 PM   #19
BBA
Real Name: Me
Member # 50
Casino cash: $753100
Like: 1
Liked 107 Times in 81 Posts
Rep Power: BBA is a splendid one to beholdBBA is a splendid one to beholdBBA is a splendid one to beholdBBA is a splendid one to beholdBBA is a splendid one to beholdBBA is a splendid one to beholdBBA is a splendid one to behold
Hate to say it but if the solenoid clicks and it don't start, it's either a bad battery, bad starter or bad battery cables. A bad starter will do it almost every time, a bad cable can be intermittant but gets worse quickly. My bet is the battery has a bad internal buss contact plate.
Now, if the clicking was just from relays under the hood in the fuse/relay box, all bets are off and it could just be a bad ignition switch.
One thing is for sure, time will tell.
Old Aug-04-10, 03:46 AM   #20
TrueLS2
Real Name: SHawn
Member # 1038
Like: 0
Yeah was deffinatly clicking from the solenoid but it wasn't your typical dead battery multiple click. It clicked once and I still had full power radio,lights ect.. How can I check if the cables are junk and what causes this to happen?
