2008 TBSS Torque Specs (other model years mostly similar) - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Modifications > TBSS How To Section > How To Do Write Up Section
How To Do Write Up Section For Procedure and Pics On How to Do Something on the TBSS
Old Jan-07-10, 11:19 PM   #1
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Casino cash: $435530
Like: 0
Liked 2 Times in 2 Posts
Rep Power: JAY4SPEED has a spectacular aura aboutJAY4SPEED has a spectacular aura aboutJAY4SPEED has a spectacular aura about
Default 2008 TBSS Torque Specs (other model years mostly similar)
Engine Fastener Tightening Specifications (6.0L) LS2
Air Cleaner Outlet Duct Clamp
7 Nm
62 lb in
Air Conditioning Belt Tensioner Bolt
50 Nm
37 lb ft
Air Conditioning Bracket Bolt
50 Nm
37 lb ft
Air Conditioning Compressor Line-to-Condenser Bolt
16 Nm
12 lb ft
Air Conditioning Compressor Line-to-Thermal Expansion Valve (TXV) Nut
20 Nm
15 lb ft
Camshaft Position (CMP) Sensor Bolt
12 Nm
106 lb in
CMP Sensor Wire Harness Bolt
12 Nm
106 lb in
Camshaft Retainer Bolts - Hex Head Bolts
25 Nm
18 lb ft
Camshaft Retainer Bolts - TORX Head Bolts
15 Nm
11 lb ft
**Single Bolt cam design **
Camshaft Sprocket Bolt - First Pass
75 Nm
55 lb ft
Camshaft Sprocket Bolt - Final Pass
50 degrees
**3 Bolt Cam Design** {edit: added on 5/1/10}
Camshaft Sprocket Bolts
25 Nm
18 lb ft
Connecting Rod Bolts - First Pass
20 Nm
15 lb ft
Connecting Rod Bolts - Final Pass
85 degrees
Coolant Air Bleed Pipe and Cover Bolts
12 Nm
106 lb in
Coolant Temperature Sensor
20 Nm
15 lb ft
Crankshaft Balancer Bolt - Installation Pass to Ensure the Balancer is Completely Installed
330 Nm
240 lb ft
Crankshaft Balancer Bolt - First Pass - Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes
50 Nm
37 lb ft
Crankshaft Balancer Bolt - Final Pass
140 degrees
Crankshaft Bearing Cap M8 Bolts
25 Nm
18 lb ft
Crankshaft Bearing Cap M10 Bolts - First Pass in Sequence
20 Nm
15 lb ft
Crankshaft Bearing Cap M10 Bolts - Final Pass in Sequence
80 degrees
Crankshaft Bearing Cap M10 Studs - First Pass in Sequence
20 Nm
15 lb ft
Crankshaft Bearing Cap M10 Studs - Final Pass in Sequence
51 degrees
Crankshaft Oil Deflector Nuts
25 Nm
18 lb ft
Crankshaft Position (CKP) Sensor Bolt
25 Nm
18 lb ft
Crankshaft Rear Oil Seal Housing Bolts (Rear Engine Cover) {edit: added better description on 8/5/2010}
30 Nm
22 lb ft
Cylinder Head M8 Bolts - in Sequence
30 Nm
22 lb ft
Cylinder Head M11 Bolts - First Pass in Sequence
30 Nm
22 lb ft
Cylinder Head M11 Bolts - Second Pass in Sequence
90 degrees
Cylinder Head M11 Bolts - Final Pass in Sequence
70 degrees
Cylinder Head Coolant Plug
20 Nm
15 lb ft
Drive Belt Idler Pulley Bolt
50 Nm
37 lb ft
Drive Belt Tensioner Bolt
50 Nm
37 lb ft
Engine Block Coolant Drain Hole Plug
60 Nm
44 lb ft
Engine Block Coolant Heater
50 Nm
37 lb ft
Engine Block Oil Gallery Plug
60 Nm
44 lb ft
Engine Ground Strap-to-Frame Nut
25 Nm
18 lb ft
Engine Ground-to-Engine Block Bolts
16 Nm
12 lb ft
Engine Harness Bracket Nut
10 Nm
89 lb in
Engine Mount Bracket Spacer
50 Nm
37 lb ft
Engine Mount Frame Bracket
100 Nm
74 lb ft
Engine Mount Nuts
50 Nm
37 lb ft
Engine Sight Shield Bolt
10 Nm
89 lb in
Engine Sight Shield Bracket Bolt
5 Nm
44 lb in
Exhaust Manifold Bolts - First Pass
15 Nm
11 lb ft
Exhaust Manifold Bolts - Final Pass
20 Nm
15 lb ft
Exhaust Manifold Heat Shield Bolts
9 Nm
80 lb in
Exhaust Manifold Studs
20 Nm
15 lb ft
Flywheel Bolts - First Pass
20 Nm
15 lb ft
Flywheel Bolts - Second Pass
50 Nm
37 lb ft
Flywheel Bolts - Final Pass
100 Nm
74 lb ft
Front Cover Bolts
25 Nm
18 lb ft
Fuel Injection Fuel Rail Bolts
10 Nm
89 lb in
Fuel Rail Crossover Tube Bolts
3.8 Nm
34 lb in
Fuel Rail Stop Bracket Bolt
50 Nm
37 lb ft
Generator Power Lead Nut
9 Nm
80 lb in
Ignition Coil Bracket-to-Valve Rocker Arm Cover Studs
12 Nm
106 lb in
Ignition Coil-to-Bracket Bolts
10 Nm
89 lb in
Intake Manifold Bolts - First Pass in Sequence
5 Nm
44 lb in
Intake Manifold Bolts - Final Pass in Sequence
10 Nm
89 lb in
J 41798 M8 Bolt
25 Nm
18 lb ft
J 41798 M10 Bolts
50 Nm
37 lb ft
J 42386-A Bolts
50 Nm
37 lb ft
Knock Sensor Bolts
20 Nm
15 lb ft
Oil Filter
30 Nm
22 lb ft
Oil Filter Fitting
55 Nm
40 lb ft
Oil Filter Tube-to-Bottom of Oil Pan Bolts
12 Nm
106 lb in
Oil Filter Tube-to-Side of Oil Pan Bolts
12 Nm
106 lb in
Oil Level Indicator Tube Bolt
25 Nm
18 lb ft
Oil Pan Baffle Bolts
12 Nm
106 lb in
Oil Pan Closeout Cover Bolt - Left Side
9 Nm
80 lb in
Oil Pan Closeout Cover Bolt - Right Side
9 Nm
80 lb in
Oil Pan Cover Bolts
12 Nm
106 lb in
Oil Pan Drain Plug
25 Nm
18 lb ft
Oil Pan M6 Bolts - Oil Pan-to-Rear Oil Seal Housing
12 Nm
106 lb in
Oil Pan M8 Bolts - Oil Pan-to-Engine Block and Oil Pan-to-Front Cover
25 Nm
18 lb ft
Oil Pan Oil Gallery Plugs
25 Nm
18 lb ft
Oil Pressure Sensor
35 Nm
26 lb ft
Oil Pump Cover Bolts
12 Nm
106 lb in
Oil Pump Relief Valve Plug
12 Nm
106 lb in
Oil Pump Screen Nuts
25 Nm
18 lb ft
Oil Pump Screen-to-Oil Pump Bolt
12 Nm
106 lb in
Oil Pump-to-Engine Block Bolts
25 Nm
18 lb ft
Spark Plugs
15 Nm
11 lb ft
Throttle Body Bolts
10 Nm
89 lb in
Throttle Body Nuts
10 Nm
89 lb in
Throttle Body Studs
6 Nm
53 lb in
Timing Chain Tensioner Bolts
25 Nm
18 lb ft
Upper Engine Mount Bracket
50 Nm
37 lb ft
Valley Cover Bolts
25 Nm
18 lb ft
Valve Lifter Guide Bolts
10 Nm
89 lb in
Valve Rocker Arm Bolts
30 Nm
22 lb ft
Valve Rocker Arm Cover Bolts
12 Nm
106 lb in
Water Inlet Housing Bolts
15 Nm
11 lb ft
Water Pump Bolts - First Pass
15 Nm
11 lb ft
Water Pump Bolts - Final Pass
30 Nm
22 lb ft
Originally Posted by ForceFed View Post
Sometimes when you stray away from the "Tried and True" you become the guinea Pig for the Pack.
08HEAVYVETTE (Jun-13-14)
Sponsored Links
Advertisement
Old Jan-07-10, 11:20 PM   #2
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Air Conditioning Line Bracket Bolt (4.2L)
10 Nm
89 lb in
Battery Cable Channel Bolt (5.3L, 6.0L)
12 Nm
106 lb in
Battery Hold Down Retainer Nut
15 Nm
11 lb ft
Battery Negative Cable
15 Nm
11 lb ft
Battery Positive Cable
15 Nm
11 lb ft
Battery Positive Cable Lead to Starter Nut
9 Nm
80 lb in
Battery Tray Bolt
20 Nm
15 lb ft
Battery Tray Brace Bolt
10 Nm
89 lb in
Engine Harness to Engine Block Bolt (4.2L)
50 Nm
37 lb ft
Engine Harness to Shock Tower Bolt (4.2L)
10 Nm
89 lb in
Engine Harness to Wheelhouse Panel Bolt (4.2L)
10 Nm
89 lb in
Engine Lift Hook Bolt (4.2L)
50 Nm
37 lb ft
Generator Bolt
50 Nm
37 lb ft
Generator Bracket Bolt (5.3L, 6.0L)
55 Nm
41 lb ft
Generator Cable Nut
9 Nm
80 lb in
Ground Cable to Shock Tower Bolt (5.3L, 6.0L)
10 Nm
89 lb in
Ground Terminal to Engine Block Bolt (5.3L, 6.0L)
50 Nm
37 lb ft
Ground Terminal to Front Fender Bolt (5.3L, 6.0L)
10 Nm
89 lb in
Positive Terminal to Underhood Junction Block Bolt
10 Nm
89 lb in
Starter Bolt
50 Nm
37 lb ft
Starter Solenoid Nut
3.4 Nm
30 lb in
Transmission Cover Bolt (5.3L, 6.0L)
9 Nm
80 lb in
Old Jan-07-10, 11:24 PM   #3
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Transission related torque specs
Accumulator Cover to Case
M6x1.0x65
8-14 Nm
71-124 lb in
M6x1.0x65
8-14 Nm
71-124 lb in
M6x1.0x28.0
8-14 Nm
71-124 lb in
M6x1.0x35
8-14 Nm
71-124 lb in
Control Lever Nut
20 Nm
15 lb ft
Converter Cover Bolt
10 Nm
89 lb in
Converter Housing to Case
M10x1.5gx45
65-75 Nm
48-55 lb ft
Cooler Pipe Connector - Steel
1/4-18NPS(SPL)
38 Nm
28 lb ft
Cooler Pipe Connector - Auminum
9/16-18 UNF
22 Nm
16 lb ft
Detent Spring to Valve Body
M8x1.25x20
20-27 Nm
15-20 lb ft
Converter Housing to Case Screw
65.0-75.0 Nm
48-55 lb ft
Extension Housing to Case
M10x1.5x33.4
42-48 Nm
31-35 lb ft
Extension Housing to Case (4WD Shipping)
M10x1.5x33.4
11-23 Nm
8-17 lb in
Floorshift Control Bolt
10 Nm
89 lb in
Flywheel to Torque Converter Bolt
60 Nm
44 lb ft
Forward Accumulator Cover to Valve Body
M6x1.0x17.7
8-14 Nm
71-124 lb in
Fuel Hose Pipe Bracket Nut
20 Nm
15 lb ft
Heat Shield to Transmission Bolt
17 Nm
13 lb ft
Input Speed Sensor Hole Plug to Pump Cover
M6x1.0x17.7
9-11 Nm
80-97 lb in
Input Speed Sensor to Pump Cover
M6x1.0x17.7
9-11 Nm
80-97 lb in
Line Pressure Test Hole Plug
1/8-27NPTF
8-14 Nm
71-124 lb in
Manual Shaft to Detent Lever Nut
M10x1.5
27-34 Nm
20-25 lb ft
Negative Battery Cable Bolt
15 Nm
11 lb ft
Oil Level Indicator Nut
18 Nm
13 lb ft
Oil Passage Cover (Spacer Plate Support) to Case
M6x1.0x17.7
8-14 Nm
71-124 lb in
M6x1.0x19.0
8-14 Nm
71-124 lb in
Park Lock Bracket to Case
M8x1.25x20
27-34 Nm
20-25 lb ft
Park/Neutral Position Switch Bolts
25 Nm
18 lb ft
Plate to Case (Shipping)
M10x1.5x35
27-34 Nm
20-25 lb ft
Plate to Converter (Shipping)
M10x1.5x15
27-34 Nm
20-25 lb ft
Pressure Control Solenoid Bracket to Valve Body Bolt
M6x1.0x17.7
8-14 Nm
71-124 lb in
Pump Assembly to Case
M8x1.25x60
26-32 Nm
19-24 lb ft
Pump Cover to Pump Body
M8x1.25x40
20-27 Nm
15-20 lb ft
Range Selector Cable Bolts
25 Nm
18 lb ft
Shift Cable Grommet Screw
1.7 Nm
15 lb in
Shift Control Cable Attachment
20 Nm
15 lb ft
Shift Control Knob Set Screw
2 Nm
18 lb in
Speed Sensor Retainer Bolt
M6x1.0x15
10.5-13.5 Nm
93-119 lb in
TCC Solenoid Assembly to Case
M6x1.0x12
8-14 Nm
71-124 lb in
TCM Bracket Nut
6 Nm
53 lb in
Transmission Control Bolts
25 Nm
18 lb ft
Transmission Control Lever Nut
25 Nm
18 lb ft
Transmission Fluid Pressure (TFP) Manual Valve Position Switch to Body
M6x1.0x17.7
8-14 Nm
71-124 lb in
Transmission Mount Spacer Bolts
65 Nm
48 lb ft
Transmission Mount to Exhaust Hanger Bracket Bolt
30 Nm
22 lb ft
Transmission Mount to Transmission Bolt
65 Nm
48 lb ft
Transmission Mount to Transmission Support Nut
46 Nm
35 lb ft
Transmission Oil Pan to Case Screw
M8x1.25x19.3
9.5-13.6 Nm
84-120 lb in
Transmission to Engine Bolt
50 Nm
37 lb ft
Valve Body to Case
M6x1.0x65
8-14 Nm
71-124 lb in
Valve Body to Case
M6x1.0x54.4
8-14 Nm
71-124 lb in
Valve Body to Case
M6x1.0x47.5
8-14 Nm
71-124 lb in
Valve Body to Case
M6x1.0x35
8-14 Nm
71-124 lb in
Valve Body to Case
M8x1.25x20
8-14 Nm
71-124 lb in
Valve body to Case
M6x1.0x12
8-14 Nm
71-124 lb in
Valve Body to Case
M6x1.0x18
8-14 Nm
71-124 lb in
Old Jan-07-10, 11:28 PM   #4
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Transfer Case Torque Specs
Transfer Case Adapter to Transfer Case Nuts
47 Nm
35 lb ft
Transfer Case Adapter to Transmission Bolts
47 Nm
35 lb ft
Transfer Case Bolts (Qty: 23)
22 Nm
16 lb ft
Transfer Case Oil Drain Plug
27 Nm
20 lb ft
Transfer Case Oil Fill Plug
27 Nm
20 lb ft
Transfer Case Oil Pump Cover Bolts (Qty: 6)
11 Nm
97 lb in
Transmission Mount to Transmission Bolts
25 Nm
18 lb ft
Vehicle Speed Sensor
17 Nm
13 lb ft
Old Jan-07-10, 11:48 PM   #5
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Propeller shaft torque specs
Propeller Shaft Yoke Retainer Bolts
20 Nm
15 lb ft
Old Jan-07-10, 11:56 PM   #6
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Rear Diff Torque Specs
Bearing Cap Bolts
75 Nm
55 lb ft
Differential Housing Cover Bolts, 8.0" Axle
30 Nm
20 lb ft
Differential Housing Cover Bolts, 8.6" Axle
25 Nm
18 lb ft
Drain Plug
48 Nm
35 lb ft
Fill Plug
33 Nm
24 lb ft
Pinion Shaft Lock Bolt
36 Nm
27 lb ft
Ring Gear Bolts
120 Nm
89 lb ft
Old Jan-07-10, 11:57 PM   #7
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default ABS system Torque Specs
Brake Pressure Modulator Valve (BPMV) Bolt
11 Nm
97 lb in
BPMV Bracket Bolts
20 Nm
15 lb ft
Brake Pipe Fittings
25 Nm
18 lb ft
Electronic Brake Control Module (EBCM) Screws
3 Nm
26 lb in
Front Wheel Speed Sensor Bolt
18 Nm
13 lb ft
Rear Wheel Speed Sensor Bolt
18 Nm
13 lb ft
Yaw Rate Sensor Nuts
10 Nm
89 lb in
Old Jan-07-10, 11:58 PM   #8
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Hydraulic Brake Torque Specs
Brake Hose to Frame Bolt
20 Nm
15 lb ft
Brake Pedal Pivot Bolt
25 Nm
18 lb ft
Brake Pipe Fittings
25 Nm
18 lb ft
Front Brake Bleeder Valve
13 Nm
115 lb in
Front Brake Hose Fitting Bolt
40 Nm
30 lb ft
Master Cylinder Brake Pipe Fittings
32 Nm
24 lb ft
Master Cylinder Nuts
36 Nm
27 lb ft
Power Brake Vacuum Booster Nuts
36 Nm
27 lb ft
Rear Brake Bleeder Valve
12 Nm
110 lb in
Rear Brake Hose Fitting Bolt
54 Nm
40 lb ft
Rear Brake Hose to Frame Bolt
20 Nm
15 lb ft
Old Jan-08-10, 12:00 AM   #9
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Disk Brake Torque Specs
Front Brake Bleed Valve
13 Nm
115 lb in
Front Brake Caliper Bracket Bolt
160 Nm
118 lb ft
Front Brake Caliper Guide Pin Bolt
Tighten the leading guide pin bolt closest to the bleed screw first.
42 Nm
31 lb ft
40 Nm
30 lb ft
Rear Brake Bleed Valve
12 Nm
110 lb in
Rear Brake Caliper Bracket Bolt
200 Nm
148 lb ft
Rear Brake Caliper Guide Pin Bolt
31 Nm
23 lb ft
54 Nm
40 lb ft
Old Jan-08-10, 12:01 AM   #10
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Parking Brake Torque Specs
Park Brake Backing Plate Nuts
135 Nm
100 lb ft
Park Brake Cable Bracket Bolts
17 Nm
13 lb ft
Park Brake Cable Nuts
10 Nm
89 lb in
Park Brake Indicator Switch Bolt
4 Nm
35 lb in
Park Brake Lever Nuts
25 Nm
18 lb ft
Park Brake Support Nuts
135 Nm
100 lb ft
Old Jan-08-10, 12:09 AM   #11
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Power Steering Torque specs
Adjuster Plug Lock Nut
75 Nm
55 lb ft
Cylinder Line End Fitting
32 Nm
24 lb ft
Cylinder Line Retaining Plate
12 Nm
106 lb in
Flow Control Valve Fitting
75 Nm
55 lb ft
Inner Tie Rod Housing
100 Nm
74 lb ft
Lower Intermediate Shaft to Power Steering Gear Input Shaft Pinch Bolt
40 Nm
30 lb ft
Outer Tie Rod Retaining Nut
57 Nm
42 lb ft
Outer Tie Rod to Inner Tie Rod Jam Nut
75 Nm
55 lb ft
Power Steering Cooler Mounting Bolts
20 Nm
15 lb ft
Power Steering Gear to Frame Mounting Bolts
110 Nm
81 lb ft
Power Steering Hose Assembly to Frame Brackets Mounting Bolts
10 Nm
89 lb in
Power Steering Hose Assembly to Front Crossmember Bracket Mounting Bolt
10 Nm
89 lb in
Power Steering Hose Assembly to Power Steering Gear Retaining Bolt
12 Nm
106 lb in
Power Steering Hose Assembly (Pressure Hose) to Power Steering Pump
25 Nm
18 lb ft
Power Steering Hose Assembly to Wheel Well Bracket Mounting Bolt
10 Nm
89 lb in
Power Steering Pump Bracket Mounting Bolts
50 Nm
37 lb ft
Power Steering Pump Mounting Bolts
25 Nm
18 lb ft
Old Jan-08-10, 12:18 AM   #12
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Steering Column Torque Specs
Adapter Support Plate
7 Nm
62 lb in
Horn Plate Switch Screws
5.5 Nm
49 lb in
HVAC Floor Duct Mounting Screw
1.9 Nm
17 lb in
Ignition Lock Cylinder Case Screws
7 Nm
62 lb in
Intermediate Shaft to the Steering Column Pinch Bolt
50 Nm
37 lb ft
Intermediate Shaft to the Steering Gear Pinch Bolt
40 Nm
29 lb ft
Steering Column Electrical Connector Screw
6 Nm
53 lb in
Steering Column Mounting Nuts
27 Nm
20 lb ft
Steering Column Trim Cover Screws Lower
3.5 Nm
31 lb in
Steering Column Trim Cover Screws Upper
1 Nm
9 lb in
Steering Wheel Nut
41 Nm
30 lb ft
Steering Wheel Position Wheel Sensor Retainer Screw
10 Nm
89 lb in
Steering Wheel Shroud Bolt
2 Nm
18 lb in
Turn Signal Multifunction Switch Screws Side
7 Nm
62 lb in
Turn Signal Multifunction Switch Screws Top
3 Nm
27 lb in
Upper Intermediate Shaft to Lower Intermediate Shaft Pinch Bolt
50 Nm
37 lb ft
Old Jan-08-10, 12:19 AM   #13
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Front Suspension Torque Specs
Brake Hose Bracket Retaining Bolts
10 Nm
89 lb in
Drive Axle Nut
140 Nm
103 lb ft
Lower Ball Joint Retaining Nuts
107 Nm
79 lb ft
Lower Control Arm Bracket Front Mounting Bolt
260 Nm
192 lb ft
Lower Control Arm Bracket Rear Mounting Bolt
230 Nm
170 lb ft
Lower Control Arm to the Lower Control Arm Bracket Mounting Nuts
130 Nm
96 lb ft
Outer Tie Rod to the Steering Knuckle Retaining Nut
57 Nm
42 lb ft
Shock Absorber Retaining Nut
43 Nm
32 lb ft
Shock Module Upper Retaining Nuts
45 Nm
33 lb ft
Shock Module Yoke to the Lower Control Arm Retaining Nut
111 Nm
82 lb ft
Shock Module Yoke to the Shock Absorber Pinch Bolt
70 Nm
52 lb ft
Stabilizer Shaft Insulator Clamp Mounting Bolts
54 Nm
40 lb ft
Stabilizer Shaft Endlink Retaining Nuts
23 Nm
17 lb ft
Upper Ball Joint Pinch Bolt
41 Nm
30 lb ft
Upper Control Arm Mounting Bolts
146 Nm
108 lb ft
Wheel Hub and Bearing Mounting Bolts
105 Nm
77 lb ft
Wheel Speed Sensor to the Wheel Hub and Bearing Mounting Bolt
18 Nm
13 lb ft
Wheel Stud
130 Nm
95 lb ft
Old Jan-08-10, 12:21 AM   #14
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Rear Suspension Torque Specs
Rear Axle Brace and Rear Axle Tie Rod to Rear Axle Mounting Bolt
190 Nm
140 lb ft
Rear Axle Brace to the Frame Mounting Nut
95 Nm
70 lb ft
Rear Axle Lower Control Arm Mounting Nut
100 Nm
74 lb ft
Rear Axle Tie Rod Mounting Bolts
190 Nm
140 lb ft
Rear Axle Upper Control Arm Mounting Bolts
131 Nm
97 lb ft
Shock Absorber Lower Mounting Bolt
85 Nm
63 lb ft
Shock Absorber Upper Mounting Nut
85 Nm
63 lb ft
Stabilizer Shaft Insulator Clamp Mounting Nuts
75 Nm
55 lb ft
90 Nm
66 lb ft
Old Jan-08-10, 12:21 AM   #15
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Air Suspension Torque Specs
Air Spring Compressor to Frame Mounting Bolts
20 Nm
15 lb ft
Air Spring Leveling Sensor to Frame Mounting Bolts
8 Nm
71 lb in
Air Supply Lines to Air Spring Compressor
2.25 Nm
20 lb in
Old Jan-08-10, 12:22 AM   #16
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Tire Pressure Monitoring Torque Specs
Tire Pressure Sensor Nut (domestic vehicles)
7 Nm
62 lb in
Tire Pressure Sensor Nut (export vehicles)
12 Nm
106 lb in
Old Jan-08-10, 12:24 AM   #17
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Wheel Torque Specs
Spare Wheel Hoist Assembly Mounting Bolts
50 Nm
37 lb ft
Wheel Nut
140 Nm
103 lb ft
Old Jan-08-10, 12:25 AM   #18
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Seat Torque Specs
Memory Seat Module Screw
3 Nm
26 lb in
Seat Cushion Frame Nut
25 Nm
18 lb ft
Seat Belt Buckle Bolt
55 Nm
41 lb ft
Old Jan-08-10, 12:29 AM   #19
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Default Seat Hardware Torque Specs
Front Seat Back Pivot Bolt
35 Nm
26 lb ft
Front Seat Back Recliner Arm Bolts
55 Nm
41 lb ft
Front Seat Back Recliner Handle Screw
3 Nm
26 lb in
Front Seat Back Seat Belt Bezel Screw
3 Nm
26 lb in
Front Seat Belt Anchor Nut
55 Nm
41 lb ft
Front Seat Belt Buckle Nut
55 Nm
41 lb ft
Front Seat Belt Retractor Bolt
55 Nm
41 lb ft
Front Seat Belt Retractor Bracket Bolt
55 Nm
41 lb ft
Front Seat Lumbar Cable Screws
3 Nm
26 lb in
Front Seat Lumbar Motor Mounting Screw
3 Nm
26 lb in
Front Seat Module Retaining Screw
3 Nm
26 lb in
Front Seat Mounting Bolt
45 Nm
33 lb ft
Front Seat Mounting Nut
45 Nm
33 lb ft
Front Seat Pan Mounting Nuts
25 Nm
18 lb ft
Front Seat Side Impact Module Screws
9 Nm
80 lb in
Front Seat Switch Bezel Screws
3 Nm
26 lb in
Front Seat Trim Panel Screws
3 Nm
26 lb in
Rear No. 1 -- Rear Seat Back Cushion Mounting Bolts
25 Nm
18 lb ft
Rear No. 1 -- Rear Seat Back Hinge Bolts
35 Nm
26 lb ft
Rear No. 1 -- Rear Seat Back Hinge Cover Screws
2 Nm
18 lb in
Rear No. 1 -- Rear Seat Back Mounting Nuts
45 Nm
33 lb ft
Rear No. 1 -- Rear Seat Back Release Latch Bezel Screw
3 Nm
26 lb in
Rear No. 1 -- Rear Seat Back Release Latch Handle Screw
2 Nm
18 lb in
Rear No. 1 -- Rear Seat Belt Anchor Bolt
55 Nm
41 lb ft
Rear No. 1 -- Rear Seat Belt Anchor Nut
60 Nm
44 lb ft
Rear No. 1 -- Rear Seat Belt Retractor Bracket Bolt
35 Nm
26 lb ft
Rear No. 1 -- Rear Seat Belt Retractor Nut
55 Nm
41 lb ft
Rear No. 1 -- Rear Seat Cushion Bracket Bolts
25 Nm
18 lb ft
Rear No. 1 -- Rear Seat Cushion Bracket Mounting Nuts
25 Nm
18 lb ft
Rear No. 1 -- Rear Seat Cushion Latch Release Bolts
10 Nm
88 lb in
Rear No. 1 -- Rear Seat Cushion Mounting Bolts
25 Nm
18 lb ft
Rear No. 1 -- Rear Seat Cushion Trim Panel Screws
2 Nm
18 lb in
Rear No. 1 -- Rear Seat Head Restraint Retractor Assembly Bolts
10 Nm
88 lb in
Rear No. 1 -- Rear Seat Mid-Position Floor Latch Assembly Bolts
35 Nm
26 lb ft
Rear No. 1 -- Rear Seat Mounting Nuts
45 Nm
33 lb ft
Rear No. 1 -- Rear Seat Support Bolts
35 Nm
26 lb ft
Old Jan-08-10, 12:30 AM   #20
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
Ok that's it for now. If anyone sees anything else not listed that you want to have, just ask.
BTW these are 2008 specs. Other years should be similar on most items.
