What is known and tried with 0MPH speedometer when a stall converter is installed? - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Drivetrain > 4L70E Transmission Help
4L70E Transmission Help Tranny Info and Upgrades including torque converters (stall)
Old Jul-02-08, 11:37 AM   #1
Warwagon
Senior Towmaster
Warwagon's Avatar
Real Name: Joshua
Member # 2476
Casino cash: $283500
Like: 0
Liked 5 Times in 5 Posts
Rep Power: Warwagon is an unknown quantity at this point
Default What is known and tried with 0MPH speedometer when a stall converter is installed?
I would like to know what is known about this and what has been tried and failed.
I am going to take a crack at solving this issue with a black box that modifies ECM inputs. Tricking computer if you will. If you have seen my chime kill mod you know how hardcore it will get.
It will be fun to try and give me an excuse to install that Yank...
My Lemon wants to make itself into lemonade at WOT!
Originally Posted by rrmccabe View Post
Joshua starred in Gone in 60 Seconds so he has experience !
2007 3SS 2WD. Simple Engineering 1.5" Thick radiator Now Available.:
Sponsored Links
Advertisement
Old Jul-02-08, 11:59 AM   #2
MikeG
Founding Member!
MikeG's Avatar
Real Name: Mike
Member # 3
Casino cash: $64450
Like: 0
Liked 4 Times in 3 Posts
Rep Power: MikeG will become famous soon enoughMikeG will become famous soon enough
mgawlik1
Go for it! But my question is...why worry about it? It only happens when you drop the throttle from a standing start.
MikeG
I'm Back!
Old Jul-02-08, 12:16 PM   #3
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Casino cash: $435530
Like: 0
Liked 3 Times in 3 Posts
Rep Power: JAY4SPEED has a spectacular aura aboutJAY4SPEED has a spectacular aura aboutJAY4SPEED has a spectacular aura about
My question is if EFIlive does the same thing, I would experiment through EFIlive myself but I don't have a stall (yet). Maybe at that point, you'd know if its in the way HPT figures the PID.
Jay
Originally Posted by ForceFed View Post
Sometimes when you stray away from the "Tried and True" you become the guinea Pig for the Pack.
Old Jul-02-08, 02:40 PM   #4
rrmccabe
aka RADIO SHACK
rrmccabe's Avatar
Real Name: Rich
Member # 243
Casino cash: $624990
Like: 102
Liked 285 Times in 137 Posts
Rep Power: rrmccabe is a splendid one to beholdrrmccabe is a splendid one to beholdrrmccabe is a splendid one to beholdrrmccabe is a splendid one to beholdrrmccabe is a splendid one to beholdrrmccabe is a splendid one to beholdrrmccabe is a splendid one to behold
I think its deeper than most think. I know some of the tuners took some stabs at it. I don't know if HPT or EFI has access to the tables required. I really dont think they would.
I suspect it will take some custom OS work. I think input and output shaft speeds run pretty deep into the system.
Old Jul-02-08, 04:01 PM   #5
Ohnoitsa60
Ohnoitsa60's Avatar
Real Name: Jake
Member # 184
Casino cash: $130099
Like: 0
Liked 0 Times in 0 Posts
Rep Power: Ohnoitsa60 is an unknown quantity at this point
Jay
Efilive is the same way, it is weird though it will go to like 3 mph and then zero.
Odd thing is my dashhawk has worked from a stab a few times
www.boltonspeed.com
Old Jul-02-08, 05:03 PM   #6
rrmccabe
aka RADIO SHACK
rrmccabe's Avatar
Real Name: Rich
Member # 243
Like: 102
Jake I have heard a lot of guys with smaller stalls say the DashHawk works when the speedo dont. So it must sample a little different...Wierd !
I really think the issue is much deeper than the backyard guys can touch. I wish Chris at Vector would get off his butt and take a look at it. He has the best ties at "resources" for that kind of stuff.
So Chris, get off your butt !! LOL
Old Jul-02-08, 06:04 PM   #7
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Like: 0
I'm thinking it has got to be something with the relationship with the input speed sensor as related to engine RPM thats throwing it out. While standing still and stalling up, the ISS and VSS both read 0. But shortly after launching the ISS will rise sharply to eventually come relativly close to engine RPM. The relation ship between the ISS and the VSS is a given value depending on what gear ratio is selected. The TCM knows what to expect as far as the difference between the two goes. It the TCM sees a deviation of that, then slipping trans DTCs get thrown. So I doubt it has much to do with the relationship between the ISS and VSS but has more to do with how fast the ISS rises in relation to the engine RPM. When you add a stall the rate that the ISS rises vs. RPM is the only thing that has changed compared to a stock vehicle. What y'all think?
If I had a stall, I could also plot it with my Tech2 to see if the VSS signal actually drops out for some reason. Or the VSS could be tapped into with a DVOM to see if for some reason the sensor is actually dropping out or is it a fluke with the TCM calculating the VSS signal. If its an error within the TCM, then there will be no fixing it.
BTW, does the speedo on the dash drop out as well when this occurs?
Jay
Old Jul-02-08, 09:08 PM   #8
Ohnoitsa60
Ohnoitsa60's Avatar
Real Name: Jake
Member # 184
Like: 0
I have a vig 2800-3000 stall
Jay dash is zero till you get out of it then jumps up
www.boltonspeed.com
Old Jul-02-08, 09:27 PM   #9
speedmaster747
The Legend!
speedmaster747's Avatar
Real Name: Luis
Member # 1497
Casino cash: $910550
Like: 7
Liked 15 Times in 14 Posts
Rep Power: speedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep pointsspeedmaster747 Gives oral for rep points
Maybe you can use the pulse signals from the wheel speed sensors (ABS) and pull it off!
Custom modifications at awesome prices (Cam swaps, tunes, Scheduled maintenance) hit me up on a PM for more info
Old Jul-02-08, 09:40 PM   #10
rrmccabe
aka RADIO SHACK
rrmccabe's Avatar
Real Name: Rich
Member # 243
Like: 102
I dont know why they need to make it so complicated for anyway. All you need is the tailshaft speed from trans. Like they have been doing for over 75 years.
I am sure they are using that calculation for something and just decided to pull the pulse out somewhere else.
Old Jul-03-08, 02:29 AM   #11
Warwagon
Senior Towmaster
Warwagon's Avatar
Real Name: Joshua
Member # 2476
Like: 0
GM cares about something they should not. The difference between Trans and converter and converter clutch slip. I figure the input sensor is for sensing trans slip under hard acceleration when the converter clutch is off. Perhaps it was intended to back off the throttle if the trans started slipping badly at WOT? This would be an improvement over the older trans and converter combined slippage code.
Well guess what the trans is going to be toast before the code is thrown and by walking you will know that yes the damn thing is really slipping! Converter clutch or trans slipping? Who cares! The entire trans has to come out and both get serviced during the rebuild. Does it matter if it was the converter or the trans clutches? Point of interest maybe.
Maybe they need a code to justify transmission repair as part of cost cutting?
Anyway I figure to tap the front trans sensor and make it follow engine RPM within factory stall of 1900 RPM. This will look like huge trans slippage, but as I point out that code is useless.
What would happen if the front sensor just flat quit? Limp mode?
Old Jul-03-08, 02:34 AM   #12
Warwagon
Senior Towmaster
Warwagon's Avatar
Real Name: Joshua
Member # 2476
Like: 0
State law requires an accurate speedo.
Who doesn't drop the throttle from a standing start? You really need to know when you hit the speed limit so you can back out.
Um, nothing better to do?
Old Jul-03-08, 06:42 AM   #13
Anointed Fighter
Anointed Fighter's Avatar
Real Name: Pat
Member # 39
Casino cash: $156300
Like: 34
Liked 8 Times in 8 Posts
Rep Power: Anointed Fighter will become famous soon enough
i think luis may be on to something with the wheel sensors....that is a viable work around that could be tapped into with HPTuners or EFILive and ploted in a scan log file, this would help me at the track with ACTUAL speeds and rpm to do my tranny tuning with....
"old age and treachery will always overcome youth and ambition"
author unknown
Old Jul-03-08, 07:10 AM   #14
rrmccabe
aka RADIO SHACK
rrmccabe's Avatar
Real Name: Rich
Member # 243
Like: 102
Get a G-tech. Wanna try one? I will send one down for you to play with.
Old Jul-03-08, 08:35 AM   #15
Anointed Fighter
Real Name: Pat
Member # 39
Like: 34
i have one in the garage and it has laid exactly in the same spot as when my homie gave it to me....
i would just like to have MPH in my logs.....just more data to tune with....
author unknown
Old Jul-03-08, 10:12 AM   #16
speedmaster747
The Legend!
Real Name: Luis
Member # 1497
Like: 7
I'm looking at the diagrams and the troubleshooting tables to see if all the sensors work on the same frequency ....
We shall see!
Old Jul-03-08, 10:27 AM   #17
Anointed Fighter
Real Name: Pat
Member # 39
Like: 34
leftcoast joe just clued me into a possible LOGGING fix.....
log the tranny output shaft rpm.....with that log you can create a guage that takes that and create an equation to multiply the tranny shaft rpm X gear ratio X tire height to calculate MPH......
I WANT MPH in my logs....and i could careless how i get it......
author unknown
Old Jul-03-08, 08:19 PM   #18
Warwagon
Senior Towmaster
Warwagon's Avatar
Real Name: Joshua
Member # 2476
Like: 0
The only other thing I can think of is doing a code segment swap with the same PCM model different car. Like GTO, Vette, to TBSS. This would be for the transmission code and VSS only. Just to bypass the TBSS specific issue via cutting support for the 'new' sensor.
Old Jul-03-08, 08:22 PM   #19
Anointed Fighter
Real Name: Pat
Member # 39
Like: 34
suburban 4L70E has already been done and NO GO on a fix thus far....
author unknown
Old Jul-03-08, 08:49 PM   #20
PsRumors
PsRumors's Avatar
Real Name: Ron
Member # 821
Casino cash: $115500
Like: 0
Liked 2 Times in 2 Posts
Rep Power: PsRumors is on a distinguished road
Pat - get an '07 and you will have MPH in your logs.....I'll trade ya.
Formerly the faSStest in Ga w 11.3 @ 120
