Apr-17-12, 06:48 PM
#101
SMFH
Real Name: Tim
Member # 2694
Originally Posted by not quick
Do the GTO's have the same issues?
No. rear sump!
We don't have a sump. It's flat!
Front sump!
Rear sump!
Apr-17-12, 06:50 PM
#102
Dustin is my BITCH
Real Name: Jay
Member # 9298
Originally Posted by ti28
No. rear sump!
Wasn't sure what you called this
Apr-17-12, 06:52 PM
#103
SMFH
Real Name: Tim
Member # 2694
That's a front...... Never looked at a GTO; my bad figured they were rear, but the pan is designed to keep oil in the front, where the pickup is.
Apr-17-12, 07:02 PM
#104
Real Name: Tony
Member # 2407
I talked to a lot of pan fabricators
prior to getting a pan. Most of what I have been told is that if you have a steep ledge on the pan this solves most pickup type problems. The gate creates the ledge that is not really there on the pan we have on our trucks. Alvin have you had a chance to monitor the oil pressure with HPTuners to see the outcome of what you pickup mod will do for both acceleration and deceleration? While I am sure this may help I was pretty much told by everyone that I spoke to without a gate or a ledge that anything else was pretty much useless. Would love to see how this turns out with the known oiling issues we have with the truck as it has been pretty much proven that the gated pan solves the oil pressure problem during HPTuners logging. Should be interesting to see if this solves the problem as well. I personally went with both the pan and an Accusump but I just put a lot of money into a motor and this was one of the cheaper things that I spent money on.
08 Trailblazer SS Silverstone, New LSX block and Bolt on Speed Tune coming up!
Apr-17-12, 07:06 PM
#105
secret squirrel
Real Name: L.C.
Member # 8355
so i called Alvin and ASKED the price..
he said its a dollar two ninety eight, and your first born.
well done Alvin. im sure it will be WELL below a C6 pain, i mean , pan conversion.....
im in for one.
'09 3ss 2wd Granite Black TBSS/PCMforLess ECM-TCM tune/intake/3 cable upgrade/brake duct trans cooler/DJM lowering kit/airbag adjust/SuicideDoors PHB/5000k HIDs/vette servo wanna build a CA compliant AR??--> www.rehindustries.com
Apr-17-12, 07:07 PM
#106
SMFH
Real Name: Tim
Member # 2694
If I can call a price I'd say 150
Apr-17-12, 07:15 PM
#107
Real Name: Wylie T.
Member # 9846
Way to go Alvin! I am in for one of these and hope you have it by the 7th. Good deal and from reading thru all these posts, I think it will solve the main issue for lots less money and effort.
[07 Black 3SS ; Maggie 2300, Built 4L85e w/Trans Cooler, SW Hdrs w/True SW Duals, CAI, LS1 Efans, Custom Seat Inlays & Dash Bezel, D&S Rtrs, Keystone Hood, 3 Gauge Pillar Pod, Lowered, Pioneer DVD, Tinted Bermuda Tails, PCMforLess Dyno Tune and much more.
Apr-17-12, 07:18 PM
#108
Dustin is my BITCH
Real Name: Jay
Member # 9298
Originally Posted by TmanSC07TBSS
Way to go Alvin! I am in for three of these and hope you have it by the 7th. Good deal and from reading thru all these posts, I think it will solve the main issue for lots less money and effort.
fixed
Apr-17-12, 07:24 PM
#109
Real Name: Bryan
Member # 14043
Wish I'da seen this befire I put the new engine in my TBSS
2006 TBSS--PCMforless CAI, e-fans, Pacesetter Armour coated headers, LS9 cam, Circle D stall convertor & dyno tuned.
Apr-18-12, 05:38 AM
#110
Member # 11747
Originally Posted by jshhammond
you see the hole in the front? thats where the pickup goes now. see the hump in the middle? thats the axle tunnel. see the thing to the left? thats what the oil filter connects to. see on top of that? left of the hump? theres metal there. thats where the pickup will go. got to punch a hole in that.
So is jshhammond right?
Magnaflow Dual Tips, 4" FWI, LS7 4" MAF, LS1 E-Fans, 160° T-Stat, & RPM Tuned. 6k Halos & Blazer Fogs, Tinted Bermuda's, & LED Conversion.
Apr-18-12, 05:44 AM
#111
Do it once, do it right!
Real Name: Brandon
Member # 9682
Maybe. I'm sure Alvin will more than likely make a kit meaning the tray may need to be swapped out but nothing modified.
07 White AWD 3SS.. Bolt ons.. Shift kit.. Stall.. Race tune by Ross Owens
AWD bolt on record holder 1.581 60' - 7.625 @ 87.77 - 12.114 @ 109.02mph
11's soon *fingers crossed*
Apr-18-12, 05:50 AM
#112
Powered by Bath Salts
Real Name: Greg
Member # 1248
im in for one.
lol, its no more work to do this than a c6 pan conversion...
took me maybe 2 hours at most to do mine including pulling the front diff out of the way.
Apr-18-12, 06:00 AM
#113
Real Name: Dale
Member # 11941
wait... you can run a c6 pan and keep it AWD?
Apr-18-12, 06:18 AM
#114
I'm a fancy man
Real Name: Jimmy
Member # 442
Status:
Online
that pan is held down with riveted metal so you'll have to drill and tap to replace it. you can't just bolt one on
Apr-18-12, 07:00 AM
#115
Real Name: Greg
Member # 1248
nope... mine is 2wd converted...
Apr-18-12, 07:47 AM
#116
Real Name: Dale
Member # 11941
oh yeah.....
Apr-18-12, 03:21 PM
#117
Hooked on speed
Real Name: Curtis
Member # 929
Cool Alvin. I'm interested.
06 Black LT 2WD (original owner) - Vector tune, CAI & HSRK, Alvin's trans cooler (brake duct mount), braided stainless brake lines
wheel
Apr-19-12, 04:14 AM
#118
Real Name: Lane
Member # 12613
Apr-19-12, 10:17 AM
#119
Real Name: Jeff
Member # 11352
Perfect timing! I have a rod bearing bout to go and a crate motor is in my near future! Pretty excited to hear a price!
Apr-19-12, 01:36 PM
#120
LT1Z CHOPOVICH CAM
Real Name: Tony
Member # 1
is this cheap enough to be put on the $2000 dollar turbo build lol.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
